Question about Dryers
Maytag gas dry no heat-
Clock not spins
  • M Linden Jun 11, 2008
    thanx for speedy answer ,lots of lint jammed...Thanx
  • 868 Answers
Check igniter (see if it glows)
air blowing out vent (maybe clogged)
Please rate this !
Posted on Jun 11, 2008
My drying is running and spinning properly but no heat is coming out to dry the clothes, any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Heat works on all cycles, drum spins, clothes are not drying they are just getting hot..
heatman101
Dec 19, 2010 | Maytag Dryers
My dryer will not heat.....the drum spins and air appears to be blowing but not heating up to dry clothes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Neptune gas dryer sense dry time at 99, little or no heat
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
Mar 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Dryers Experts
