Question about Kodak EasyShare DX6490 Digital Camera
Tricks to opening Kodak C513
HI,
I'm goign to try to replace a lens on my Kodak C513 Easy Share. You said there were some tricks you could share. Please help.
  • luvzimusik Jul 12, 2008
    Well, i tried opening my Kodak easyshare Z740 several times so carefully and somewhat ripped the ribbon wire almost halfways, now the picutre quality is messed up with straight vertical lines.... where do i get the part and how do i replace it?
    laila
  • chamberskb Jul 15, 2008
    I have a Dx6490 that I need to open and get all the sand out of (wife fell). I have taken all the screws I could find -even the two under the rubber flaps on the side. Still can't get it apart. HELP
    Novelist:
  • 153 Answers
Affraid that offer was for the DX6490, Ive never had a C513 (plenty of C3xx and C6xx though) on the bench. But, most of the C series are fairly straight forward.
This is generic C series info, yours will differ, there may be speakers in the way mic wires etc so proceed with caution and keep a lookout
read all of this before starting
first you need to take static precautions, using a metal strapped watch or something metal around your wrist connect yourself to earth, a good place is your computer case (it dose'nt need to be on, just plugged in), loosen a screw and wrap a piece of wire round it then the other around your wrist.
undo all the screws in the camera (the 6490 is the only one Ive found so far with hidden screws so shouldn't be a problem there).
The front and rear casings should now un clip and leave you with the chassis if the front case wont come away, look for a screw down a hole, often behind the LCD (on other kodaks not usually c series).
Keep an eye on the bars and springs retaining the battery and memory card door they tend to spring off and get lost, also note how they are positioned
IMPORTANT SAFETY NOTE, Before starting leave the camera a couple of days with no batteries in (or follow the discharging instructions). Once open locate the flash capacitor (big black tube with 2 wires) and take a voltage reading, if its still high (50v or higher) put it down and come back to it tomorrow or using INSULATED clips connect a 20k ohm 1 watt resistor across it for a while that will pull it down.
If your in too much of a rush that cap will bite and hard, 350v (10,000v if you touch the transformer) when the flash is freshly charged and if it bites its likely to fry the camera too, as well as that your guaranteed to drop it.
Ok so now the camera is safe to work on, if you haven't already remove the LCD, then remove all the screws retaining the main board. Most C series cameras have several ribbon cables and the battery posts are soldered through the main board, you need to un-clip all the cables and de-solder the battery connections, also loosen the switch board (on top) as there is usually a connector hidden that will just pull apart but it needs a bit of movement.
Now the ccd (image sensor) some are on a ribbon cable (but you will be able to see that) some are mounted on the back of the board. some will come away ok with the board others have a pair of extra screws through holes in the board, if the board is being reluctant (but be carefull) at the lens end have a closer look for screws through holes in the board near the lens. Pull the board away carefully as the IR filter will either stick to the ccd and may drop off or it will stay in the hole in the back of the lens, there should be a little square rubber gadget, again don't loose it and for goodness sake don't touch the class filter or the ccd a fingerprint will ditch it.
if the ccd is on the main board put the board in a clean plastic bag and put a little piece of tape over the hole in the back of the lens, especially if the filter is still in there as you may need it later and you want to keep it clean
If it is the ribbon cable type, you should now have the board off and be able to get to the 2 or 3 screws that hold the main lens assembly in place, remove them and carefully jiggle the lens free, keep an eye out for the ribbon cables their very easy to damage.
fit the new lens assembly and screw it in place.
get a clear plastic (to prevent dust contaminating the lens and sensor) bag big enough to get the camera and your hands in and put the camera chassis and the old lens in it, (if ccd is on a ribon) unscrew the screws holding the ccd in place and swap them over
remembering that there should be a rubber gasket on the ccd then the infra red filter in the hole the ccd goes in
You can skip the ccd swap if you like but I cant guarantee that the colour and contrast will be the same as it was, Ive not had a problem when swapping them but strictly the camera should be calibrated for the new ccd and you wont have the equipment or software to do that. I always keep the same ccd with its main board where possible.
now its a reverse operation to put it back together, don't forget to re-solder the battery contacts.
Best of luck
Posted on Jun 12, 2008
Kodak easyshare c1450 lens stuck open lens obstructed
You need to remove the batteries and remove the memory card. Then reinstall the batteries. Finally, press and hold the "ok" button, the power on the camera. This is a factory reset trick. It fixes approximately 40% of all error messages on the KODAK EASY SHARE CAMERAS. But of course, no one is gonna be kind enough to help somebody out, they just want to take your money!
May 19, 2012 | Kodak Genuine Easyshare C1450 Lens And Ccd...
My Kodak Easy Share C513 will not turn on, I have changed the batteries, cleaned it, and it has not been dropped or damaged, it also has not gotten wet.
It could be dirty battery contacts. Take a pencil and use the eraser to burnish the contacts. It will clean them nicely. The springs are hard to do, be careful not to twist them up. If you can, use a little sandpaper glued to the end of a pen to clean them. Report back with results.
Jul 01, 2011 | Kodak EasyShare C513 Digital Camera
Kodak easy share c182"lens error 211" will not
I went with other advice, gentle drop on carpet sorted it :-)
Jun 09, 2010 | Kodak Easyshare C182 12MP Digital Camera
My lens focuses only intermittenly
If you have the settings on AUTO the camera will automatically adjust to what it thinks will make the best picture.
Try and use the SCN.
You can also switch the flash on and off as you wish.
For more tips and tricks on picture taking please follow this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=38/13915/39&pq-locale=en_US
Jan 02, 2010 | Kodak EasyShare M1033 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
Tricks
Hello, I don't quite know what camera you are referring to,you just mentioned an EASY SHARE ???? What model are you working on ?
e-mail me at hounddogellie@gmail.com
Best Regards, Russell
Jun 19, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
184 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
