Question about LG GMA-4020B Super-Multi DVD-RAM/R/RW&CD-R/RW Writer, Original Retail (DVDRRW4020B) Burner
LG DVD-RAM My LG dvd-ram is 2 yrs old and it has become slow in reading the discs and in burning and it is not able to read some discs what should i do to fix it
  • Anonymous Nov 24, 2008
    my dvd HL-DT-ST DVD- RAM GSA- H55N not working how i do
Before you attempt to repair it (I agree, unlikely to be cost effective), consider buying a CD/DVD Lens cleaning kit and follow the instructions to clean any potential dust build up on the lenses.
I think this to be a more likely explanation for the problems you're having, than a worn out part. If, like most people, you do do not periodically "spring clean" the inside of your PC, the amount of dust that can build up is quite surprising. Once dust gets inside the lenses of Optical Drives, performance can rapidly deteriorate.
Dust also affects the performance of all moving components and vital cooling functions inside PCs. Regular spring cleaning and lens cleaning are high in the list of sensible precautions a user can take to extend the life span of a PC and its internal components.
If lens cleaning does not solve the problem (likely if you've left it too late), then the purchase will not have been wasted. I strongly recommend buying a new, state-of-the-art, multi-format DVD-RW. Regular use of the the lens cleaner plus the internal spring cleaning will help preserve the new drive's life.
The only valid reason I can think of to attempt to repair the damaged drive, if cleaning it doesn't work, would be to add to your range PC hardware repair skills. Otherwise, repair will almost certainly prove to be the more expensive option, with the added possibility of error in ordering the correct components. Although the internal componentry of conventional optical IDE (previous platform) and SATA (current platform) drives follows a standard engineering framework, there is a huge variation in the design of individual brands and models. This means that the component parts designed for one particular drive are not necessarily an identical match for those of another.
Good luck.
Posted on Jun 12, 2008
    Genius:
  • 1,019 Answers
HI,
after 2 years use. dependant upon how many disks have been read/written. the drive will have worn out.
the main problem will be the laser head.
but also consider that the motor-laser-rails et,c. have all undergone extreme usage.
if you want or are competant to repair this. i,d suggest a new laser replacement. a laser guide. this is a plastic piece that moves the laser backwards/forward on the laser rails.
the job itself is not a massive one, however when you purchased the drive, it may have been around £80 or $150.
a suitable replacement brand new drive, is now only about £25-$50. recommend pioneer 112.
the answer to your question, is yes the drive is repairable, but probably not cost efficient.
Mike @ Compurepair.
I have DVD RAM (Super Multi Secure disc drive) from LG . It starts burning and stops suddenly with a 'speed breaking' sound at 0% itself.May it start burning and end at different progress like 10% 20% with...
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty ?
good luck
Aug 30, 2010 | LG Computers & Internet
Hello, I have a Toshiba Satellite P105. The DVD drive on it, says it is a DVD-RAM. In properties it read as a HL-DT-ST DVDRAM GMA-4082N. I bought this being told this drive supports Dual-Layer burning. Now...
Here are the specs on your drive...
Specifications of LG GMA-4082N General
Buffer 2 MB OEM Hitachi-LG Connection ATA Slimline yes_icon.jpg write speed
CDR 24 x CDRW 16 x DVD-R 8 x DVD-RW 4 x DVD+R 8 x DVD+RW 4 x DVD-RAM 3 x read speed
CD 24 x DVD 8 x
Oct 13, 2009 | Toshiba Satellite P105-S6024 Notebook
My LG GSA 55HL Multi Burner with litescribe Will Not Burn With DMA Enabled on My OLder Computer 8 yrs old.Its A 1ghz intel with 512 mb Ram,Not enough RAM? Will burn dvd without DMA but takes a really long...
Go here and download DVD shrink.
http://www.afterdawn.com/software/video_software/dvd_rippers/dvd_shrink.cfm
Install it then do the following.
Insert DVD Cancel when it attempts to play
Open DVD Shrink
Select Open Disc (top Left) then OK
It will take about 1 1/2 mins to read the disc. Ignore what it says on the right ot the screen.
On the left under full disc back up click on the disc icon not the folders underneath then click on back up on the top.
You can if you wish just click on the main movie folder then back up if you don't want trailers or subtitles included.
DMA encryption is there for a reasonn and that is because the companies do not think you are allowed to make back ups of films you have bought.
DVD Shrink also has other uses EG if you have a DVD9 and want your back up on a DVD5 it will happily do it for you.(movie folder only reccomended here though) and better still its FREE!
Jul 28, 2009 | LG GMA-4020B Super-Multi...
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
I can't burn anything on my Optodisc DVD 9.4 GB DVD Ram Discs
According to the manual available on Apple's site (http://manuals.info.apple.com/en_US/MacBookPro_17inch_UserGuide.pdf)
"Your MacBook Pro can read but not write to DVD-RAM discs."
Dec 15, 2008 | Optodisc 4.7GB DVD Ram Rewritable Media...
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Computers & Internet Logo
120 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
