Question about Dishwashers
Dishwasher seems to b stuck on drain cycle
Hi my dishwasher is 3 years old never had a problem until now. I loaded the dishwasher switched it on and it was making a sucking/glugging noise as if it was trying to drain although there was no water in the bottom. I wondered if there was a blockage further down and poured a few pans of water in which disappeared immediately but then it carried on making this sound. Our model only has 5 buttons - on/off switch and 3 programmes and rinse only so I don't know if it has stopped midcycle although the previous time I used it earlier in the day I didn't notice any probs. thanks for any advice before I have to call the repairman - by the way I'm no DIYer!
  • 1 more comment
  • JeremyF Jun 11, 2008
    At first the dishwasher drain seemed blocked and I used a suction plunger and then it started draining, even with all dials 'off'. It only stops draining when I unplug it! If I try any setting it just keeps the drain motor running and does not try to fill up again.
  • Anonymous Sep 20, 2008
    I have a Favorit 6150 with the same problem. Even with all buttons off it still seems to be stuck on wanting to drain. Any solution will be appreciated.
  • wolfwilleatu Oct 19, 2008
    Yes I have the same problem with my bosch SHU33A. i HAVE TRIED EVERYTHING
AEG Favorit 443
Serial 025 582 307
Product nr 606 281 135
Posted on Jun 11, 2008
    AEG Favorit 443
    Serial 025 582 307
  • 868 Answers
Model and serial number ???Helps alot
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
Bosch Dishwasher continuous fill/drain
Have same problem with 2 second cycling. I resolder at the point of heater relay. Thought I had solved the problem of running forever on 1. Now have this "new" problem that you have described.
Nov 11, 2009 | Bosch SHU5315UC Dishwasher
Water will not drain out of dishwasher
trace it back along the outlet pipe and you will find on the pump a unscrewable plug be carefull as you are going to get a few litres of water over the floor
Apr 08, 2017 | Hotpoint 24 in. HDA1000Z Built-in...
Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Jul 13, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Whirlpool GU980SCGQO not draining and I'm expecting 27 dinner guests Sunday
Ok, there are a couple of things it could be. The pump motor could be stuck, which is the most likely. Remove the bottom panel and look underneath. Spin the impeller until it spins freely, then try to start the dishwasher. Make sure the door is open before you do this, so that the impeller doesn't run while your hand is in it =)
Also, check the drain hose for a check valve. Sometimes these get stuck in the wrong position and it won't drain well. If none of these work, let me know and I'll help you further.
Apr 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag model 920 d/w will not drain
can you hear the drain pump trying to pump? or does it do nothing? when it should be draining
Feb 19, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Dishwashers Logo
456 people viewed this question
Top Dishwashers Experts
