Power Inverter I purchased a Jensen JP30C power inverter to power my laptop and it is blowing fuses in my car. Any ideas why?
    Genius:
  • 1,601 Answers
Is it powered by the cig lighter?
The reason for the problem, is that there are many things in the circuit, and the converter is "the straw that broke the camels back". It puts the draw to more than the fuse can handle.
If there is any way, I would:
1. See if the car has an extra cig lighter power connection
2. Get one that hooks directly to the battery.
3. Make sure that the converter is not bad.
Posted on Jun 11, 2008
Overloaded inverter will not power up
Have you checked the voltage going to the inverter? Sounds like you may have exceeded the load that he inverter can handle but not enough information to confirm that from this end. You mention "plugged into my van battery", possibly you have this plugged into your Cigar Lighter? Mega fuses are usually really high amperage fuses, much more than the inverter could blow and save the inverter. The fuse should be matched to the load and about 50% higher. If the device is rated at 10 amps, a 15 amp fuse will provide protection where a mega with 500 amps will act like no fuse at all to the inverter.
Apr 12, 2017 | Inverter Electronics - Others
Car fuse blows when i play a game
You should try replacing the fuse with a higher amp fuse. It may be that the fuse resistance level is to low. You may need to repair or replace the mobile inverter if it still blows a stronger fuse. It may be that the inverter is malfunctioning and causing the fuse to blow. Check it for loose wires or screws etc., or send it back.
Nov 07, 2013 | Targus APV12US 150W Slim Line Mobile...
My name is Gena. The VEC024B that is being used by our field technicians are having problems with the fuse blowing in their work vans. Their vans are equipped with laptops.
Hi Gena, the inverter is a 400 watt unit. This is not a rating for a continuous load. You do not mention which fuse is blowing. This could be the fuse in the inverter or the cigarette lighter (power source) fuse. In either case, a fuse blowing could be a short circuit, something in the inverter shorted, or too much load. I am going to look at the too much load side of things. Not knowing how many laptops are being used, with the inverter if you have a 20 amp fuse in the cig lighter, this will allow you 20 amps X 12 volts = 240 watts. I would not run the inverter over 240 watts because of overheating issues. So, 240 watts will run 3 laptops. Just the laptops. Most laptops draw around 70 watts. check your power supplies on them to find their rating. If you exceed the 240 watts by combining the ratings, then you can expect trouble with your inverter. It will give 400 watts, but this is a temporary condition only. Another inverter will be needed or a larger one installed and it being connected directly to the battery (with a fuse of sufficient size installed). You could also (let us say there are 6 computers) charge and run 3, and the other 3 are running on their batteries. After an hour, switch so that the 3 running on batteries now are charging as well as running. The other 3 are now charging.
I hope this helps. If you have any other questions please provide additional information. Such as the size and location of the fuse blowing. The laptop power supply ratings.
thank you
Oct 15, 2010 | Vector VEC024B MAXX SST Power Inverter
My 400 watt inverter will not charge my laptop the fuse keeps blowing?
Your laptop PS has big condensers in the input. Even supplied by mains through 6A quick fuse or automatic breaker it will drop first time, but may hold the second. Your inverter may be has fast fuse 2 - 5 A. If not so fast it may carry the initial load.
Hint: If you are not "both left handed" you can connect  20 - 200 Ohm (2 - 10 W) resistor in series to your Laptop Power Supply. After the initial start of the inverter you can shorten the resistor by a 3 - 5 A switch.
Jul 01, 2010 | Vector 1000w Power Inverter
I have my jensen in a 2006 pontiac vibe. after leaving the dome light on all night, i boosted off the car and now my stereo won't come on! checked all fuses what's wrong? it was fine before.
There is a protection fuse in the back of the radio itself, sometimes in the wire comming off the radio. alot of times when boosting a car it will receice a power spike, and blow this fuse.
Aug 15, 2009 | Audiovox JENSEN VM8012 3" WIDESCREEN...
Jensen VM9312 Stopped working
MAKE SURE U CHECK THE FUSES UNDER THE HOOD.
Mar 31, 2009 | Jensen's VM9312 Car DVD Player
Power inverter blows fuse in car
overloading fuse on cars wiring try direct connection to battery
Dec 27, 2008 | Audiovox Jensen Jp 20 Single Outlet 160...
Blowing fuses
Are you sure you don't have the positive and negative power wires reversed?
Does the fuse blow without remote voltage applied?
Nov 09, 2008 | Jensen JPA285 Car Audio Amplifier
Blowing fuses on vm9410
use a bigger fuse or a smaller one
Oct 10, 2008 | Jensen VM9410 Car DVD Player
Jensen xa2150 amplifier
Check and see if its dirty inside, dust and smoke are known to cause problems via shorting or not making contact... sometimes your fuses are a bit over the wall so it would be best to replace them... and check if you have a fuse between your battery and the power cable to avoid over powering the amp
Dec 18, 2007 | Jensen XA2150 Car Audio Amplifier
Computers & Internet Logo
David Payne
David Payne
