Question about Indesit Washing Machines
When i am washing my clothes with my washer dryer its fine unless i change the temp whilst washing
    Genius:
  • 1,122 Answers
DON'T DO THAT,YOUR ONLY SUPPOSE TO SET TEMP AT START OF CYCLE,YOUR INTERFERING WITH WASHER CYCLE-MIKE
Posted on Jun 12, 2008
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
Jan 02, 2015 | Crosley Washing Machines
How do I change the rinse cycle on CAE2743BQ?
They... SHOULD be somewhat wet. This isn't a dryer, it's a commercial washer. After washing your clothing, you'll need to dry them.
Aug 03, 2014 | Whirlpool Washing Machines
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
What is thebest tepmerature for white garments
Set your water temperature to "cold" on your clothes washer. Unless your clothes have oil or grease stains, cold water is usually adequate to clean white and colored clothes. In fact, washing clothes in cold water allows fabrics to retain their color and strength longer.
Feb 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi, I have kenmore washer and after washing my clothes getting some white stains on them. How to solve this problem?
If you are using a liquid fabric softener , then start using dryer sheets instead OR using less softener . Also be sure you are using the correct temp setting for softener " disolvement " . Re-washing the clothes should take out the spots . If you have dryed the clothes , may take several washes to remove the spots .
Aug 05, 2010 | Kenmore 24032\24036 Top Load Washer
I have a sour smell coming from my washer that does not seem to go away, what is the problem? I have seen many other postings on the internet about their having this problem, seems to be the washer.
After the odor has been removed washing habits need to change so it doesn't return. Washing machine odor is caused by
1. Overuse of detergent. Use no more than 1 tbsp of whatever detergent is used (unless washing soiled clothing).
2. Using fabric softener because it's dispensed in the rinse cycle. Dryer sheets or dryer balls are better options. Dryer sheets can also be overused and coat the inside of the dryer with siliconized chemicals that cause clothing to retain odors. Sensors inside the dryer can also be affected. The sheets can be torn in half or thirds
3. Using mainly cold water for washing is fine but makes preventive maintenance important. A hot wash or soak as your last cycle on wash day will help to dissolve residue.
4. Many front loading washer have a filter/trap that will catch debris. A partially clogged filter/trap can cause draining problems and odor. Save money on appliance repair by cleaning it yourself. Consult your owner's manual for instruction.
Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Apr 10, 2009 | Hotpoint First Edition FEW12 Front Load...
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
