Question about NEC Computers & Internet
Nec vl350 usb not working in vista - NEC Computers & Internet
Hi, First of all check that the usb is compatiable for your pc and the os.Check your installation and trouble shooting manual.
Or try connecting it to some other pc running vista.
check the device manager for the usb port and is active.
Install the device driver from cd if provided.Check the hardware for physical connections or any IO conflicts.Finally also try that usb is enabled in CMOS setup an make it to auto mode.
More troubleshooting tips if not solved, all the best
Anand.
Posted on Jun 11, 2008
Nec powermate vl350
You may download the manual from here.
Jan 15, 2013 | Computers & Internet
I recently acquired an NEC SuperScript 1260 laser printer but I need an adapter cable so it will work off my computer (Vista). I need a pin connector for the printer on one end and USB for computer. The...
The NEC SuperScript 1260 has a parallel printer port. So you would need a parallel to usb adapter. These aren't very expensive; depending on the brand and length you'll pay between $8 and $15. See https://www.amazon.com/TRENDnet-Parallel-Converter-10-6-10-9-TU-P1284/dp/B0007T27HS or https://www.amazon.com/Sabrent-Parallel-Printer-Adapter-CB-CN36/dp/B00IDU0T1Y Alternatively, if you have a desktop, you can find a PCI or PCI-e add-on card with a parallel port, depending on the slots available in the system. These will be closer to $20 to $30. Then you need a standard parallel printer cable. Many computer parts sites, including Amazon.com, will have both.
A bigger problem may be the printer drivers. NEC did not update the drivers after Windows XP. (Some XP drivers will work under Vista.) NEC doesn't supply the drivers on their site: https://support.necam.com/Printers/Drivers/ . They refer you to the original driver CD that came with the printer. A few sites may have these drivers online. However, I haven't seen a link to a known trust-worthy site with the XP driver.
I hope this helps. Please add a comment if you need more information.
Sep 15, 2017 | NEC SuperScript 1260 Laser Printer
I cannot get my nec mobile pro 900 to sync with my laptop i downloaded activesync from: http://www.microsoft.com/windowsmobile/en-us/downloads/eulas/eula_activesync45_1033.mspx?ProductID=76 i downloaded...
Which one did you do first: Did you install ActiveSync 4.5 first, or did you try installing the driver first?
The best way to do this is as follows:
  1. Download and install ActiveSync (4.5 is what i use both at home and work and it works great with the NEC 900 and 900C's.
  2. Restart your Windows XP Machine (I assume you don't have Vista)
  3. Next, follow the instructions for the installing the NEC 900 usb drivers (these drivers should be installed AFTER installing ActiveSync... (it seems to work that way without problems for me).
  4. Next, restart your xp machine again.
  5. Now, connect your NEC MobilePro 900 to your Windows XP machine, and it should perform smoothly.
If this does not work for you, you can contact the folks at usedhandhelds.com, they sell and repair, as well as provide support for these machines.
Hope this helps
Apr 17, 2009 | NEC MobilePro 900 Handheld
Nec USB 2.0 CardBus on HP Compaq nw9440 with Vista Ultimate
Hi I have a Compaq Presario 919EA with xp operating system and others have a nec pcmcia usb 4-port and when the insert locks the operating system
Feb 01, 2009 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
The internal bluetooth dongle on my nec versa p8310 is no longer recognised by vista, when i turn the bluetooth on it comes up with a window that says the usb device i have connnected is not recognised
If tried so many ways ti fix it but still it wont work, buy a usb dongle or card that supported by windows vista.or try to reinstall the driver for this device.the moment you bought this pc does it have vista already?
May 28, 2008 | NEC Computers & Internet
Vista problems with NEC SuperScript 870
If you load the printer drivers from a Windows XP install disk (in the i386 directory), that worked for me.
Feb 22, 2008 | NEC SuperScript 870 Laser Printer
Micros system cdrw dvdi
Yhe NEC site may have an uodate.
But Optical drives should prove no problem as such
Are your sure it is the driver or may be the USB Root
Check System Hardware.
Jan 25, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
NEC SuperScript 1800 Laser driver to use for Windows Vista
Use the HP LaserJet 4 Driver. That's what I did and the printer works fine.
Nov 15, 2007 | NEC SuperScript 1800 Laser Printer
Computers & Internet Logo
126 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
