Question about LG Flatron F700B 17" CRT Monitor
LG f700b monitor
How To Repair LG F700B CRT Monitor With Power Blink Symptom
  • drixer Jun 12, 2008
    LG F700B is the model of my crt monitor it is still the same solution with my first post?
    what is FBT 6174z 1031 is it the same with the other..?my crt monitor model is LG F700B
HOW TO OPEN LG E700SH MONITOR
Can you give some more details, what action do you take that fails to open the monitor?
what happens when you attempt to open it?
Aug 28, 2012 | LG Flatron F700B 17" CRT Monitor
LG monitor not powering on.
LG clor monitor F1700B17'' power on but display not coming please whycan do it solution
Mar 04, 2011 | LG Flatron F700B 17" CRT Monitor
What is default monitor screen setting LG flatron e700sh
1280x1024 resolution
I would try using a 60hz refresh rate though it does state the monitor will support up to 85hz
Feb 18, 2011 | LG Flatron F700B 17" CRT Monitor
My lg t705sh monitor start after 45 minites of the power on
i am also having the same model,but mine was just power light blinking and screen is blank even not starting after long hours.
Sep 14, 2010 | LG Flatron F700B 17" CRT Monitor
I got a black and white signal (picture ) also it is very weak , i have to increase the brightness to be able to see the black and white screen , when i turn it on some times after 5 or 10 or30 minutes it...
it usual problem with LG monitors. u can fix it just by soldering vedio board epecially vedio ic affixed on crt. bt do it gently becoz any bridging of solder may damage ur microcontroller.
Sep 07, 2010 | LG Flatron F700B 17" CRT Monitor
I want to know ls flatron monitor shape settings
there is usually a default setting in the os menu.
Nov 12, 2009 | LG Flatron F700B 17" CRT Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
LG F700B Lines at top of screen
HEY BUDY
i have same problem (exactly same!!)
see here i hope it is usefull
http://www.fixya.com/support/t2664392-lg_f700b_raster_problem
if it solve your proble please notify me
Feb 09, 2009 | LG Flatron F700B 17" CRT Monitor
Monitor screen appears yellowish
resolder components on the CRT neck circuit! the color ICs or Transistor connections migth have loosen up!
Dec 06, 2007 | LG Flatron F700B 17" CRT Monitor
LG Flatron F700B 17" CRT Monitor Logo
483 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
