Question about Sony Ericsson Walkman W810i Cellular Phone
My Camera When i click my camera button .. its going to the black screen for about 2 seconds ,then coming up ""Another application is running. Close it, and then start the camera"" . But i havnt gpt any applications running, ive tried also turning everything off like my bluetooth, an it still doesnt work. What could i do to fix this ? :S
  • ahmadrza Jun 12, 2008
    my mobile is doing some fool acts means suddenly battry low and it switched off i just need adress of w810i mobile phone driver plzz give me address of that thanx
  • Anonymous Jun 13, 2008
    ans it
    Brigadier General:
  • 7,752 Answers
Your phone needs to be reflash to correct this error.
ahmadrza - you can download it from www.topony.com but this is not a free site....or you can try sourcing it on the net
Posted on Jun 14, 2008
I can't use my camera. when i used it , it will immediately hang. what should i do ?
When the camera function won't work usually it is because too many applications are running at once. Click your menu button when you are on the main screen and select "Switch Application." You will then see the applications that are still running. Select one and exit it and then you should be able to operate the camera. Usually if you just close one or two applications you should be fine.
Mar 16, 2011 | RIM BlackBerry Bold 9700 Smartphone
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Another application is running. Close it and then start the camer
Hi, buddy, I faced the same prob and this solution helped me. This was 6 months back and now, the prob has risen again and I am going to try this solution again.
The direct page link from where I copied this info is http://www.esato.com/archive/t.php/t-148845,1.html
Lets see if it works again.
Hashmi
-----Solution-----about (Blank Camera Screen)
i have the solution! cause i faced same Problem before.
well, the solution is:
1. Turn off the w850i for at least 7 hours! not less than 7 hours!
2. Turn it back on. and when it gets the network wait like 10 seconds.
3. hit the Silver button (the camera shortcut button). and you will see it is Working!!!
Hope that helps!
________________
Ahmed
Jul 11, 2009 | Sony Ericsson W850i Cellular Phone
My camera is not working/ black screen.it tells me to close apps
Alright, I just had this problem. I dont know how this happened, but some settings were changed. If you go to media and press the menu button then go to options. Now change device memory limit to 15mb and reserved picture memory to 2mb. Now try your camera, it worked for me.
Jun 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
Blackberry 8130 Curve Camera Troubleshooting
I had this problem and I've tried everything posted and nothing worked so I just started messing around with my phone and may have figured it out. Here's what I did.
NOTE: I AM NOT RESPOSIBLE FOR ANYTHING THAT HAPPENS AND YOU ARE SOLEY DOING THIS ON YOUR OWN AT YOUR OWN RESPOSIBLITY. Good Luck
1. Click the Menu Button
2. Scroll to Options Icon (the wrench) and click it
3. Click Advanced Options
4. Click Applications and wait for the Apps to load.
5. Scroll down and delete the apps that you dont need (see what I deleted)
6. I first deleted ICQ Messanger by scrolling over it and selecting the menu button then clicked delete, then clicked Yes and let it reboot
7. After it rebooted I clicked the Camera button on the side and it worked after I rebooted
8. Then I went back in and deleted Yahoo Messanger and let it reboot again. (This is up to you)
9. Last I deleted Windows Live Messenger and let reboot once again. (This is up to you)
I deleted these because I didnt use them anways. These were the only 3 apps that I deleted since I never used them. If you want, you could even delete Brick Breaker if you dont play it but I wouldnt delete any other Apps other than these.
Jul 01, 2008 | Cell Phones
Black screen
Go to this link for UK. Near the top of the window, there is a search box. Type in 37383 and click the box right below it that is labeled "Search by Case ID". Then click the Search button. All information and instructions on the resulting page are applicable to the UK. There is a button at the bottom to contact Canon Tech Support.
Jun 14, 2008 | Canon PowerShot A70 Digital Camera
Won't turn on at all and the focus is stuck
Black screen in Veo Digital Studio or Yahoo! Messenger.
Veo Digital Studio:
Start the Veo Digital Studio and then click on the "Take a Snapshot" button. The camera light should turn on.
Click the "Settings" button and then click the "Advanced Settings" button.
On the Video Quality screen, click the "Defaults" button to enable the default settings for the camera.
Click "OK" and then "OK" again. You should now see the live video on your screen.
If you still see a black image on the screen, try disabling the overlay feature to see if this resolves the issue:
Unplug the camera from the computer.
The Veo Digital Studio will indicate "Digital Video PC Camera is not connected to this computer." Click "OK" to this message.
Click the "Quick Fix" button and then check in the "Disable Overlay" checkbox. Click "Fix it" and then close out of the Veo Digital Studio.
Plug your camera back into the computer and then try the Veo Digital Studio again.
Yahoo! Messenger:
Make sure that your camera works and you can see yourself by following the steps above for the Veo Digital Studio.
Close the Veo Digital Studio and then start Yahoo! Messenger.
In Yahoo! Messenger, click on Tools->Start My Webcam.
If you see a black screen, in the My Webcam window, click on File->Preferences.
On the left side of the Prefences window, select Webcam.
Click on the "Camera Source" button. In the Camera Source drop down menu, select the Veo PC Camera or Veo Web Camera and then click OK.
Click on the "Camera Settings" button and then click the "Defaults" button.
Click "OK" and then "OK" again to close the Properties window.
If you still see a black screen in the My Webcam window, please contact Yahoo! for more assistance or refer to the Yahoo!
Messenger Webcam Help page at:
http://help.yahoo.com/help/us/mesg/webcams/index.html
Good Luck.
Live, Love, Laugh.
Mar 24, 2008 | Veo Stingray
Help
Veo Digital Studio:
Yahoo! Messenger:
Check this page :
http://www.veo.web.tr/tr/Stingray/kb_tshoot.html
http://www.veo.web.tr/tr/Stingray/kb_faq.html
Good Luck.
Live, Love, Laugh.
Nov 05, 2007 | Veo Stingray
LCD Screen Goes Black
well u can turn it on by holding the vlume button for about 2 or 3 seconds. and u can also access the camera, media player and profile settings from the front by holding the camera button for about 2-3 secs.
Sep 19, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
60 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
