Question about Samsung Televison & Video
My rear projection tv has a lot more green on it and slightly to the side and all is fuzzy!
    Sergeant:
  • 291 Answers
Navytek is right,
but don't change any IC's without throughtly checking all caps & resistors in the convergence ckt. those IC's don't go bad easly.check for leaky capacitors 1st.
You will need the schmatic or you will have to do trial & error.,
Posted on Jun 14, 2008
    Problem Solver:
  • 6 Answers
The convergence ic's may be shot.. check surrounding electro caps too.
Posted on Jun 12, 2008
I have a Samsung floor model TV model number HCP4363WX/XAC I think it's the color aliment but picture looks fuzzy it kinda looks like it 3D how do I fix this issue.
That tv is a rear projection tv. It uses 3 CRT tubes that are Blue, Red, and Green and converges the pictures on top of each other. The convergence chip needs to be replaced. Samsung Akai Projection TV Repair Kit for one or more of the following...
You can order the repair kit from here and it comes with step by step instructions for the repair. I have personally used them before with a lot of success.
Jan 25, 2017 | Samsung Televison & Video
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Green line on left side of an image and a red line on right. Such as around a face. Colors just don't line up and picture is very fuzzy. Had another old rear projection and it had a way to align it. Can...
Your other model was more than likely a CRT projector where you coulod manually align the Red/Green/Blue guns. The one you have now is more than likely an LCD projector which can't be readily aligned. Sounds like the panel is failing.
Mar 13, 2011 | Zenith R57W46 57" Rear Projection...
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Jul 08, 2010 | Philips 43P8341 43" Rear Projection...
Picture fuzzy and brighter in center. convergence good on red but blue and green only show in center crosses. green and blue glow around figures.
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair World.com,Tv Repair Kits.
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture problem
I have the exact same problem a month ago. I replaced the two STK392-110 ICs with the STK392-110T adn everything went back to the way it was.
Jul 01, 2008 | Toshiba TZ50V61 50" Rear Projection...
Green ghosts
these tv are night mares best case get rid of the projection tv period go with a lcd flat pannel and make sure it dsnt have a lamp
Dec 30, 2007 | Samsung HCN4727W 47" Rear Projection...
Sony rear projection
My dad has a sony rear projection tv and had this same problem. A shop had to replace one of the color tubes(?) (green, red, or blue) had to be replaced. The shop said this was common with Sony rear projection TV's.
Dec 11, 2007 | Sony KP-51HW40 51" Rear Projection...
Open Questions:
Televison & Video Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
