Question about Lands Phones
Cordless phone will not dial a local number commencing with the digit 9. Model KX-TC2100NZB
  • Pearson Chilumbu Jun 13, 2008
    siemens c75 has a problem. it says release cc:041
Hi, I have to start this with a question as where are you on the planet. As for example some part of the world uses "tones" (DTMF) and others use decadic which is pulse based exchanges. This issue requires some diagnosis type convesation but appart from that I would check that the cordless phone has good power and that the rechargable batteries are in good condition.
Posted on Jun 12, 2008
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Dial lock
    This worked on my KX-TG3611BX and might work on yours:
    Turn the dial lock off using the following method:
    1 {MENU} --> {#} -> {2} -> {5} -> {1}
    2 Press {*} -> {7} -> {0} -> {0} -> {0} 3 {Save} -> {Yes} -> {OFF}
    Aug 27, 2011 | Panasonic GigaRange KX-TG2432 Cordless...
    Help me to unlock "Dial
    I have Panasonic cordless model : KX-TGA361BX ...my kids dial lock the phone and forgot the password. please tell me how to unlock it
    Aug 01, 2011 | Cell Phones
    Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
    You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
    There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
    Carl
    Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
    When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
    Carl
    Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
    How do i do a + sign on a cordless if i want to call overseas?
    Ignore the + sign, you do not dial it, similar to how you do not dial a - sign in a local number.
    Mar 04, 2011 | Panasonic KX-TG1033S Cordless Phone
    I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
    The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
    The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
    In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
    System speed dials requrie access to system program 001.
    If this does not work on your system, please comment back with your actual system model number.
    Carl
    Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
    PANASONIC KX-TG2340JX TROUBLESHOOTING
    my small dghutor turn the dial lock on by mistake .we trry to turn it off but we couldn't coz we don't know the password No. so plz hellp us the Model No KX-TG2340JX Panasonic
    Mar 14, 2009 | Panasonic KX-TCD535GM stahlgrau-metallic...
    My cordless answering machine is showing set date and time and i cannot use it to call out. The model is KX-TG1840
    Do you have it plugged into a wall jack?If so do you have dial tone?If you have dial tone can you make it go away by pressing a digit on the hand set?Just because it is cordless does not mean you can call out on it without having it plugged into a wall
    jack.The wall jack also has to be connected by your local phone company,
    tk46
    Jul 22, 2008 | Panasonic Lands Phones
    Lands Phones Logo
    65 people viewed this question
    Top Lands Phones Experts
    Are you a Lands Phone Expert? Answer questions, earn points and help others
