My desk top's bios sow that system fan rpm =0 and cpu =4234, and hdd ;s light staying up but my desktop is restart time by time . and whenever it shaw a bios update error ,and then desktop shutdown and no display but smps, s on and power light on but display not come and no beep from motherboard at startup .
  • 114 Answers
You could of:
A: Blown your CPU.
B. Blown your RAM.
One of them have to replaced. I suggest you try the RAM first cause it is the cheapest. if you can't do it, have your local PC shop take care of it.
Posted on Jun 11, 2008
Why my cpu fan stays on all the time
CPU fan is on all the time in computers.
Apr 20, 2015 | Acer Computers & Internet
When i open my samsung 150 plus i see nothing but an underscore blinking what should i do
first please check the CD compartment for any cd int then restart your computer press Del and enter bios and make sure to make the first boot hdd-0 and second boot CD drive and also make sure the hard disk is detected in the bios if the all this is done save the bios and restart the system then press F8 and click safe mode and wait for few minutes for the desktop when the desk top come then double click my computer and right click the drive and scan the drive if the safe mode fails to open re install in the mbr file and the fix boot
Jul 30, 2011 | Samsung N150 (36725723009) Netbook
I am running Wxp on my Acer L100. After about 15
first things first pls check if the cpu fan is seated properly.
if not pls try to reseat the cpu fan, but before doing it put thermal paste on top of the cpu to haver a better contact on the cpu
if the fan is seated properly check the rpm of the fan on bios mode see if the rpm of the fan is fast enough.. if not then there's the problem.
this things only happens if the cooling system of your processor is malfunctioning. Your built in hardware monitor tends to turn of the computer to prevent further damage,,
Jan 11, 2010 | Acer Aspire L100 PC Desktop
I have hp d260 cpu, In my bios i have auto detect hdd settings, but it shows no hdd inspite of working hdd attached. when we tries to manualy detect the hdd it shows but as soon as we restart the pc it...
Nov 30, 2009 | HP Computers & Internet
My sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Sep 16, 2009 | Sony VAIO VGC-RB40 PC Desktop
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
PC does not boots / does not start
Since your system reboots even if you stay in the Bios setup the problem with your system might be because of heating up of the proceesor, which might be caused if the fan CPU fan is rotating slowly or is not rotating at all. If the fan is rotating slowly change the cpu fan and try to reinstall XP
Jun 29, 2009 | Computers & Internet
Hp Mecia Center m7060n fan failed, new fan not detected
the fan must be the correct fan
i guess you meant the CPU fan, ? desktops can have 2 or 3 fans.
the fan has 3 wires, in many cases, the 3rd wire is a RPM tachometer that if not correct the PC can not read RPM
if RPM reads 0 the PC will be very upset. and do that.
my guess you bought the wrong fan, and is super easy to do
giving the many fans
on some PCs the BIOS monitors the fan RPM and heat sink temperatures, or both, and tells yous fan bad for either failing
on my PC here, now, I can go in to bios and see both live sensors
RPM and Temperature. this allows for easier diagnosis
i dont think your PC has that page in BIOS to do monitors for trouble shooting, in fact mine has 3 fans all 3 are monitored, now.
high end PC .
this older desktop , only the m7200 pages are there. at hp.
so cant look at the fan nor BIOS.
i use a windows program that lets me watch the fan speeds
and all CPU and GPU core temperatures. (ask) its free.
the troubleshooting guide at HP stops short at this problem
says get it fixed. so you want to fix it your self sure.
so talk to one of the top, CPU/HEATSINK/FAN makers
and buy this from them.
if the fan spins fast and RPM is 0 wrong fant
if the fan spins fast and RPM is ok, then the BIOS dont like the CPU temperature... this has 3 causes.
fan dead. or slow. or wrong fan installed
heat sink fins packed in lint as all do ever year.
heat sink thermal bond compound failure, common.
Jul 18, 2017 | HP Media Center m7060n PC Desktop
P5NT won't boot
I went throught this and it is really silly. The P5N-T motherboard has a problem with some of the new energy efficient CPUs. The fix was to insert an older CPU and upgrade the bios and then it would recognize the new CPU. If you happen not to have an older 775 CPU laying around (most people do not), it might be easiest to return it and get a different board - or maybe the store can upgrade the bios for you.
Oct 05, 2008 | Computers & Internet
System fan
you may have less fans than possible readings. That 0 rpm fan may be absent and so it is not the problem.
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
David Payne
David Payne
