Question about Epson LX-300+ II Matrix Printer
Printing problem the printer prints half the character if for example its am an it breaks it into two and only prints the top half yet the test page it prints it well
    Scholar:
  • 107 Answers
Dear friend this is problem with Printer setting u want to reset
  • switch off the printer
  • hold by pressing LL/FF & online button
  • & switch on the Printer
  • Default setting is printed on paper
  • get full printing & restart the printer
u r printer will get default setup
if this information is useful for u please rate me .......
Posted on Jun 11, 2008
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
Why does only the bottom half print?
Do all trouble shooting computer printer management tools. Try other printing chores. "test page" . Is this picture, or print situation. If picture, try another example. Check on Owners manual in PDF format on Printer install cd for trouble shooting section. No luck Google printer make model, there may be a common problem among multipul owners. Warranty status?
Jun 07, 2015 | Office Equipment & Supplies
Printer prints random characters
Hi Erica,Try to shut it off, but if you can't, unplug it. Then try canceling it and plug it back in.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 06, 2014 | Brother Office Equipment & Supplies
Have just installed Windows 7 Ultimate and downloaded/installed the driver for Panasonic DP-C322. After successfully installing, I printed a test page that consisted of 100's of pages, some blank and...
The "test" output should have been one page.
If the printer properly interpreted the data-stream that it received, it _would_ have generated just that one page. However, if the printer is not "interpreting" the data-stream, but instead is printing it, character-for-character, then you could have gotten the mountain of output that you got.
Turn the printer off. Turn the printer on. Try again to print your own, small, "test" page.
May 05, 2011 | Panasonic WORKiO DP-C322 Printer
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
We are setting up new TallyGenicom LA800. However, printout has dot or period in between each characters printed. Hence, a single row info is printed on two rows. What seems to be the problem?
It would be strange for the printer to print dot between each printed character without this coming from the system.
As a check the first thing I would recomend doing would be to print a self test print on the printer, you can do this easiest by printing a menu print.
To print a menu print put the pritner OFFLINE
Press SETUP
Press the button under MENU
Press the button under PRINT.
The printer should print out its configuration page, if this has dots between each character then this defiantly means you have printer problems.
You can try defaulting the pritner back to factory settings, this is down by holding down the four buttons (1, 2, 3 & 4) under the LCD display whilst powerind the printer on.
If the menu prints OK, then there is some sort of other strange system or communication problem.
If the pritner is connected via serial, check the serial settings on the pritner also chack the pin configuration of the connector used to print to the printer.
Try printing from another system or application to identify what might be causing the problem for example an application or driver problem, perhaps try printing from a PC directly to the pritner to check the interface on the printer is OK.
Check the emulation setting on the pritner ensure this is correct.
Aug 02, 2009 | Epson Stylus Photo 2100 InkJet Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
Sqeaky paper feed
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=238800&prodTypeId=18972&objectID=c00001617 the HP site for your printer Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris. Cleaning the outsideback to top of page Clean the outside of the printer with a cloth that has been dampened with water. NOTE: Do not use ammonia-based cleaners on or around the printer. Cleaning the paper path and print-cartridge areasback to top of page Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Use the following steps to clean the paper path and print-cartridge areas: 1. Turn the printer off and unplug the power cord. 2. Open the top cover. Figure 1: Top cover opened example 3. Remove the print cartridge. Figure 2: Print cartridge removed example CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems. 4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects. Figure 3: Paper path area and print cartridge cavity example 5. Reinstall the print cartridge and close the top cover. Figure 4: Print cartridge reinstalled example NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place. 6. Plug in the power cable and turn on the printer. Cleaning the fuserback to top of page Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs. To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval. The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place. NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning. Use the following steps to run the cleaning page: 1. If the printer model includes a duplexer, open the rear output bin. 2. Press example(Select button) to open the menus. 3. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button). 5. Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button). 6. Perform the following to complete the cleaning process. 1. Remove all paper from Tray 1. 2. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button). 3. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button). 5. Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer. 7. If the printer model includes a duplexer, close the rear output bin. Let me know if that helped. Good luck, Tim
Mar 14, 2007 | HP LaserJet 2300 Printer
Epson LX-300+ II Matrix Printer Logo
321 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
