Question about Panasonic Microwave Ovens
NN-V659W microwave blowing the 10A fuse, when starting the microwave heating
    Genius:
  • 1,036 Answers
Sounds like the magnetron has charred and is now shorting.
You could try cleaning it, but a replacement is safer in the long term.
Posted on Jun 11, 2008
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
NN-A774SBBPQ Invertor & Cat-Clean model.
no 3rd fuse as far as i know just the two on the mains pcb and the plug i would test all three fuses again but if the short has gone back up to the control panel them that might be why its not coming back on if it has blown the control pcb it will show up as ablack mark on the pcb sorry cant be nore help its the sort of thing i would need to see as it could be a door micro switch as well gd luck dont forget to unplug the unit
Oct 05, 2009 | Panasonic Microwave Ovens
Microwave Oven has died
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Sep 30, 2009 | Microwave Ovens
Panasonic NNA554W blows 10a fuse when microwave comes on
Possibly the interlock monitor switch is bad or out of adjustment. This switch is designed to create a short circuit across the power line (and then blow the fuse) if you attempt to defeat the door interlock and operate the oven with the door open. A shorted capacitor or diode could also cause the fuse to blow. Because of lethal voltages inside and the possibility of microwave leakage if repairs aren't done correctly, you are best off leaving microwave service to professionals.
May 15, 2009 | Panasonic NN-SN657SMicrowave Oven
The main 10A 250V Fuse keeps on blowing up everytime I use my Microwave function. This does not happen when I use the Convection Oven.
Possibly magnatron to earth fault.Needs testing profesionaly.(microwaves can kill even when unplugged.)Regards grandadfixer
Oct 15, 2008 | Microwave Ovens
NE1856 Microwave
error 81 message is usually a fault in a relay....found on the LV transformer located beneath the noise filter....(noise filter is a ciarcuit board mounted to one side, should see 2x 10a fuses on it and a small 1.25A)...underneath, a circuit board...thats the lv transformer assy.
Check the 10A fuses first....if they are ok, change the entire transfromer assy.....easy enough to do, the part number is A692M3310GP
Hope this helps
Oct 05, 2008 | Panasonic NN-2505A Microwave Oven
Panasonic NN-S789WC - No power on Display, Fuse OK, bulb Lights
The fuse will be a white or gray ceramic fuse, and you really can't tell if it's blown without actually measuring it. If a new fuse blows when you hit START, you probably have a shorted high voltage capacitor. If you have replaced the fuse and still have no display, then it sounds like there's a problem on the control board. The control board has a built-in surge protector which can short (and smoke) and when it does, it will cut the power to the control board, but not blow the fuse. We repair these nationwide for only $39.95 postpaid. If you or a friend want to check it out or send the control unit in for serivce, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 02, 2007 | Panasonic NN-S789 Microwave Oven
Microwave Ovens Logo
167 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
