Defination what is a graphic card, definition
  • saadatsherwa Jun 11, 2008
    define graphic card plz
  • 31 Answers
From WIKI:
A video card, also referred to as a graphics accelerator card, display adapter, graphics card, and numerous other terms, is an item of personal computer hardware whose function is to generate and output images to a display. It operates on similar principles as a sound card or other peripheral devices.
The term is usually used to refer to a separate, dedicated expansion card that is plugged into a slot on the computer's motherboard, as opposed to a graphics controller integrated into the motherboard chipset. An integrated graphics controller may be referred to as an "integrated graphics processor" (IGP).
next time do some research. GOOGLE it.
Posted on Jun 11, 2008
Is 1GB graphics card compatible with intel 946gzis motherboard?
The Intel D946GZIS is capable of supporting any PCIe 1.0 x16 graphics card. It can also support a PCIe 2.0 x16 graphics card, but the overall performance of that card will be halved.
Memory in a graphics card does not affect compatability.
-Morphix13
Aug 25, 2011 | Intel D946GZIS Motherboard
I can't find the definition of my video graphics so please help me this is the description of the card Type : ATI ATI Mobility Radeon HD 5470 Graphics (switchable) up to 1799 MB total graphics...
You can find a description at AMD.com
http://www.amd.com/uk/products/notebook/graphics/ati-mobility-hd-5400/Pages/hd-5470-specs.aspx
You can also download the drivers from this page.
Aug 08, 2011 | Computers & Internet
My graphic card don´t work, one
> touched a power-cable, and the PC turned off
Definitely a short-circuit. Try replacing the graphic card.
Jan 19, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Monitor on my DC5000 SFF will not turn on, it says there is no signal.. I tried a different monitor and that did not power on either when i tried. Could this be a graphic card problem? Is there any way I...
Yes, it definitely sounds like either your graphics card or video cable are bad.
Before you get a new graphics card, make sure you check all of the connectors on the video wire and the graphics card and make sure no pins are bent, broken off, or stuck in the plug in the back of the graphics card.
Another option is to try a completely different video cable that you know is working. If you do this and your monitor still does not turn on, it's almost definitely a bad graphics card and needs serviced/replaced.
I hope this helps :)
Best Regards,
James
Nov 27, 2010 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
I have 4 gb kingston pen drive can i use it as graphic card?????????
hit it with a hammer and then plug it to your usb port. it will definately work just like you have upgraded your graphic card to 3.7 gb.
Jul 06, 2010 | Kingston flash memory card - 256 MB -...
My 530 MT goes through graphics cards.
Def Wouldnt be putting in more cards, there is obviously something wrong. Either your Power supply aint putting out enough power or the pci slot that your cards are getting put into is messed up. First of all run without a graphics card(if u have integrated graphics card). Do some stability test with software like Sandra(www.sisoftware.net). If ur pc ran nicely and stable then definately it is a power supply issue.
Oct 20, 2009 | Dell Precision 530 Minitower 2.4Ghz...
Fixed function pipeline geforce4 MX 4000
That card is too old for games. I assume you only have a pci slot for graphics which is not suitable for gaming- new motherboard or pc definately needed!
Mar 14, 2009 | Nvidia GEFORCE 4 MX440se / MX 4000 VIDEO...
Define our laptop compaq presario c700
You need the driver for the Graphics card that is installed in your computer. Download Belarc Adviser and install it, and run it. This will tell you lots of information about your computer.
Under Display, it will tell you the type of graphics card you have.
You need to find and download the latest driver for it.
For instance, I have an nVidia Graphics card, so I would go here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
If I had an ATI card, I would go here:
http://ati.amd.com/support/driver.HTML
When you have downloaded and installed your driver, you can adjust your Resolution in the Display settings.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Compaq Presario 700 470024-192 Notebook
How to make up a design using the dreamweaver?
Macromedia Dreamweaver for the first time, or on a new site for the first time, you need to define the Web site so that Dreamweaver can work with it. This process includes naming the site, placing the local files on a directory on your hard drive, and showing Dreamweaver where those files will be published on the Web. Follow these easy instructions to define a new Web site for Dreamweaver .
First, you should go to the "Site" menu and choose "Manage Sites".
As you can see from the image below, this will open a dialog window. Choose "New Site" from the "New" button.
Open Dreamweaver and Start the Site Definition Wizard
Name Your Site
Using Server Technologies on Your Dreamweaver Site
Where Should You Edit Your Dreamweaver Site Files
Defining Access to Your Dreamweaver Site
Always Test Your Connection
Site Check-out and Check-in with Dreamweaver
Review Your Site Definition
Your Site Now Appears in the Manage Sites Window
Start Editing Your Files in Dreamweaver
Oct 11, 2007 | Macromedia Dreamweaver MX 2004
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
