Question about Philips Televison & Video
I selected the wrong option under system menu, player was working fine, now itshows scrambled, i can't see how to go back, and correct the problem, is ther any way to reset my dvd player phillips model dvd622/37...plz help
    Genius:
  • Philips Master
  • 1,550 Answers
Turn on the dvd,with the tray open press arrow> right and mute on the control that deactivate the function scan.Good luck
Posted on Jun 11, 2008
Rear speakers do not work , also in set up menu they are grayed out.
hi there
when playing radio, the rear speakers do work because you have configured that. in your dvd player however, you may not have configured it yet.
Correctly insert the jacks at the back of the dvd player and at the same time, check the menu of your dvd player and check the audio settings. Under the audio settings of your dvd player menu, select the 5.1 or 6.1 audio profile.
hope this helps.
Feb 05, 2008 | Mintek DVA-8700 System
Beginning to regret my purchase discussion
Yeah a lot of people are having problem with that system..
here is what you have to do
UN PLUG YOUR POSITIVE BATTERY POLE FOR AT LEAST ONE HOUR
this will cause your system to rest,
Upgrade your firmware to the latest one possible , chek your manufactures web site for the firmware and details on how to do this
ensure your settings(peferecnces are correct)
and thats it you should be fine
cheers
Jan 05, 2008 | Kenwood DNX7100 Car Video Player
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
Recorded a movie on the DVR, played it & recorded it onto a Sony DVD-R with the Sony RDR-VX525, I believe it finalized & did everything it should. However, it won't play. It says disk error. I went...
what happened was that you probably chose a disc speed on the DVD that was too fast or slow for the dvd players that you are putting it in to. Try re recording it but when under the DVD section, on your remote, choose REC Mode till it says SP. That one should work on just about any dvd player. I had the same problem with mine. Here is a step by step instruction on how to dub from VHS to DVD correctly. If you follow all the steps, you should be fine :) http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
Jan 20, 2011 | Sony RDR-VX525 DVD Recorder/VCR
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
When I look at the titles of the songs on my mp3 player it is in a language that looks Chinese and there is not even a Chinese language option on the device. What is wrong with this stupid Emerson 4gb mp3...
Use a paperclip or pin to push the RESET button located on the back of the MP3 player. Once you've done that, select ENGLISH as the language under the SETTINGS menu.
Jun 25, 2009 | Emerson Audio Players & Recorders
Phillips 14PT6107S/05
I found this on the net:
Try this, there are 2 versions of this set, one of these will work.
14PT6107
ENTER 062596 ON REMOTE
WITHIN 5 SECS PRESS MENU
SERVICE MENU SHOULD APPEAR
SELECT DVD
PRESS ENTER
OPTION 1 USE RIGHT BUTTON TO SELECT REGION "ALL"
NOW PRESS MENU 3 TIMES TO EXIT
OPTION 2 TYPE 00 PRESS OK
THEN MENU THREE TIMES
GO IN TO STANDBY AND POWER BACK UP
Option 2 worked for me. The thing I was failing to do was going in and out of 'standby'.
Also there is no 'all' instead 00 = 'all'
Jun 12, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Cable channels 5 and 6
not sure on this model , but check your menu and see under the setup menu if it has a band select option or tuning band. sometimes the autoprogram may pick up the wrong band. Make sure it is set correctly. I had this where it would just make some certain channels bad.
Nov 01, 2007 | Zenith A25B33W 25" TV
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Televison & Video Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
