Question about Compaq Armada 1700 Notebook
Please help me with my COMPAQ ARMADA 1700
Every time I open my Compaq Armada, it gives me a Black Screen with message: "Non-System disk or disk error; Replace & Strike any key when ready. Please help me asap. I really need to use my laptop. Classes have already started. Thanks!
In a post to another armada 1700 user, I described in detail how to recover bios settings.
the bios setup program has a menu for boot priority. usually floppy first, then cd, then HDD.
Changing boot-order may render your HDD visible to the BIOS.
IF YOUR BOOT-SECTOR IS FRIED, USE SBM...
in operating system installation, the HDD space is first partitioned.
Then, filesystems (C: D: E: drives),  are created within those partitions.
But there's a hidden part right at the beginning of the HDD.
This is the boot sector which lists the starting address of each partition.
when the computer is switched on or reset, the bios queries the boot sector to locate the BOOTABLE partition and the system files therein.
If your boot sector is scrambled, it can be rewritten no probs but in the mean-time, download 'smart boot manager' (SBM).  Make the floppy and boot from that. you will be presented with a list of available partitions. choose one to boot from.
REMEMBER, IF AN OLD LAPTOP SEEMS TRULY SCREWED, PUT THE HDD IN A MORE MODERN LAPTOP, BOOT WITH A LINUX LIVE CD (i recommend puppy linux--choose option XVESA), AND RESCUE YOUR PERSONAL STUFF ONTO A BLANK CD/DVD/USB.
Posted on Sep 30, 2008
    Scholar:
  • 47 Answers
Double check to make sure there is no floppy disk or CD-ROM disk inserted when you boot. If there is definitely no floppy or CD, your hard drive may have crashed or been corrupted. You can try installing Windows again, but it might not work if your hard drive is faulty. If it's faulty, you'll need to head to the local computer repair shop or have a geek friend help get and install a new one, then reinstall Windows.
Posted on Jun 11, 2008
    Genius:
  • 2,785 Answers
Plz check the hard disk cable if its ok then your hard disk may be bad.
SOURCE:
Non system or system disk error
Bad HDD? Have you tried a system restore/recovery. Reboot, at preboot repeatedly tap the F-11 key try to get to system restore/recovery.If it's an old machine you may need to replace the HDD.
Nov 06, 2012 | Compaq Armada M700 Notebook
My compact armada e500 displays bios error system haulted message
remove and reseat the Hard drive .. it may have come loose from the connections
Feb 17, 2010 | Compaq Armada E500 Notebook
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
My Compay Armada E500 will not start up
first replace the disk by new one if problem persists then resold the connectors on mbd by h/w chiplevel engr
Nov 01, 2008 | Compaq Armada E500 Notebook
Error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Sep 03, 2008 | Compaq Armada M700 Notebook
Help with compaq armada 1700
Sounds like your Hard Drive is gone, or you have a floppy disk in drive or cd in drive, could be a CMOS setting wrong also, but I would suspect the Hard drive is shot on a machine this old. P.S. I am running an Armada 1700 right now. Your HDD door should be on the bottom of the machine about 3"X3" with a 1"X3" lip that is hinged and has a catch on it, you need to release the catch and see if it even has a hard drive in the caddy, it will slide towards the front of the machine, slide it back towards the back it is only held in by the cover's foam and may have come dislodged. Some things to try.
Jul 14, 2008 | Compaq Armada 1700 Notebook
Issues with my compaq armada
dear mitchiko
did you tried by changing the cables?if the problem still persists than it might be a problem with your motherboard.Contact your vendor then.
Apr 04, 2008 | Compaq Armada 1700 Notebook
Compaq Armada M700 - failure to boot from CD
Hello Blessie,
This is Romeet,i shall try and help you with this problem. Before formatting for a new installation of w2k, did you delete your partitions and create a new partition or did you just overwrite the old installation partition?Besides i hope you did a backup of your data before any of above processes in the event you might need it later on? Please let me know about the partitioning and i shall try and help further accordingly as most likely it looks like a Disk Partitioning Misconfiguration / Problem
Regds
Romeet
Dec 01, 2007 | Compaq Armada M700 Notebook
My compaq Armada E500 wont come on
Replace hdd couse the pc dont recognize hdd..First go to the bios and load optimal default or optimized default and pres F10 and restart
If it wont work just buy NEW HDD
Oct 19, 2007 | Compaq Armada E500 Notebook
This means that your hard drive has failed or has become disconnected and it cannot find the boot.ini to enable Windows to start. When you say youv'e tried all discs which disks do you mean?
Jan 09, 2007 | Compaq Armada 1500C Notebook
Compaq Armada 1700 Notebook Logo
578 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
