Question about Sony Playstation 3 (PS3) Console
PS3 40gb, no DNS available
I have been attemtping to go on the internet through the use of a wireless device. I am able to get the IP adress part to work but the DNS part always fails. I've tried every way I can think of to fix this problem. I even used a cable and tried it wired, but the same thing happened, I got the IP adress but no DNS. If you know of a way to fix this problem, somone who can, or where I need to go your help would be greatly appreciated, thanks.
  • 6bam6bam6 Jun 11, 2008
    Yeah I've tried it with both of them. The problem is though that the DNS server I have isn't even working....
    Well, the first time I tried those, it succeeded, but the internet still wasn't working though. Even though it was connected it still said that "An error occurred during the communication with the server. This is a DNS error. (80710102)"......
    Now it isn't even working at all....
  • 67 Answers
Have you used the automatic settings for the two different connection types (wired and wireless)? You should only need to enter this information if you want to use DNS servers other than the ones provided by your ISP.
You can read more about internet connections on the PS3 with this link: Playstation.net
Posted on Jun 11, 2008
  • Robert Monroe
    Robert Monroe Jun 11, 2008
    I would suggest a free DNS server like OpenDNS
    208.67.222.222 and 208.67.220.220
Network connected but no wireless internet
Please go to command prompt and type ipconfig /all. This will show you the dns adresses assigned to the etehrnet or wireless adapters. Try to ping that dns address. If you are not able to ping the dns address, assign static ip and dns addresses to the computers.
May 07, 2010 | NetGear RangeMax Premium Wireless-N...
I set up my linksys wireless router this morning on my desk top which has high speed or DSL and I like to have it on my laptop also. I need instructions on how to ave it on both computers,
If your laptop has a wireless card built in - or external, you will be able to get the wireless signal.  You need to open your wireless dialog - Start > My Network Places > View Network Places
Jan 02, 2009 | Computers & Internet
Wireless connection
My PS3 would only connect using WEP encryption , so I had to downgrade my WPA capable router in order to go wireless.
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
I cant get wireless internet!
it might be that your security settings are wrong make sure that you chose the right encryption settings for example wpa or wpa2 if you have a dns issue make sure you can use your wireless with other devices. if cant then reset your access point
Jun 17, 2008 | Sony Playstation 3 (PS3) Console
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ip adress config/dns server
when using a static IP you must also get the DNS server addresses from your router's manufacturer. the primary/secondary DNS for D-Link routers are 4.2.2.2/4.2.2.3 respectively. contact the customer support line of your product or do a Google search for"_______ dns" (____ being your product name)
Jan 13, 2008 | Computers & Internet
Ps3 internet
Have you tried to find the settings automatically? Your router may be stopping the ps3 from access it to retrieve the information
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
