Question about HP Compaq Presario V5000Z Notebook
Compaq V5000 Laptop wont recongnise / charge battery anymore
I brought an after market battery for my V5000, and it worked a treat for about two weeks. Then all of a sudden the computor would only run for about 2 mins before powering off instantly.
A local computor shop found that by removing the battery, and AC power, and attempting to start the computor ( to drain all power ) then only powering on with AC fixed the problem. However if the battery was put back in it reverted the old problem.
I sent the battery back, and was given a replacement - which also worked perfectly for about two weeks, then did exactly the same.
Second time around the computor shop found that by up dating the bias they could get the computor to run with the battery installed.
The persistant problem is now that the laptop does not 'see' the battery, although displays it's remaining power ( 3% ). Consequently it wont charge the battery, even though the battery indicator shows it charging when on AC power.
I took the battery to a battery shop, and they said that they suspected that the power board may be faulty - rather than it being a battery related problem.
Any feed back appreciated.
  • Jon Webb Jun 11, 2008
    I've pretty much come to that, although the orginal battery is dead, hence the replament. I'm trying to establish the problem, rather than sending back a perfectly good battery for the second time if it is the computor's issue. Thanks.
  • GL Marsden Oct 03, 2008
    I have the axzct same issue. The diference is the charging indicator shows the attery charging, however when the laptop is unplugged fron the AC, the computer dies. I purchased a brand new battery with the same results. I checked the power settings, AC adapter, even tried calibrating the battery all with no luck. Any info would certainly be appreciated
    Problem Solver:
  • 6 Answers
I have a problem with a V5000 ( can you point to me which is the Charging IC) ??? works fine but no charging
Posted on Aug 29, 2008
    President:
  • HP Master
  • 2,022 Answers
Yes may be bcoz u already replace 2 battery but the problem is same may be the charging ic problem (in mother board) or the battery quality is not good try with the original battery and see. if still u facing the same problem then show it to repairing center and get it done.
Posted on Jun 11, 2008
My laptop wont charge so i brought a new charger but it still wont work.
It could be the battery... they tend to wear out over time. If you run the laptop with the charger plugged in, it works fine, right? It just won't hold the charge?
Aug 31, 2010 | HP Compaq Presario CQ61420us Notebook
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Needing to fix a compaq presario v5000
The screens on these computers can and will go dead after a while, afterall its an old computer..try an external desktop monitor by plugging it in the back(blue port)
If you want a new screen go here
Good luck..and if you have any questions about your armada just ask.. I have 5 of them.
Oct 01, 2008 | Compaq (241995001) Plug-In Module (Laptop)...
Laptop isn't working
have the charger tested, the original battery may have been flat, because of charger failure rather than battery failure. try an automotive connector if one is available
2c worth
Jul 11, 2008 | HP Compaq Presario V5000Z Notebook
V5000 problems
what you need 2 do is either take the whole laptop back 2 where you brought it or even the battery cause you have a faulty battery.
most laptop batterys last for at least 5-10 years and after that no matter how much you charge them up they alwayz seem to be flat.
so my suggestion is get a new battery or take it back to the place that you brought it from and than get it replaced for free as long as you have your recept.
Jul 06, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
Compaq v5000 wont turn on
Shorted MOSFET in the secondary most likely.. These are trash..
Nov 14, 2007 | Compaq Presario V5120NR Notebook
HP Compaq Presario V5000Z Notebook Logo
300 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
