Question about Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx : Camera Issue
In my applicathon i need to use camera, but it is not supporting to set size of the camera view.its only taking fullscreen. i need to set camera screen for small porsion of my device area in my application.
Insert cam
Posted on Jun 14, 2008
Remove camera
open up the back of your v3.take out the battery..
then remove the 4 little rubber screw plugs on the 4 corners of the screen side of the flip/there are 4 little star type screws in there.remove them remembering what hole each screw came out of.some v3s have different size screws in the holes.then you'll see the flat ribbon cable going from the camera to the pc board of the screen.remove it and gently work the camera out of its holder..be careful.use a flat type screw screw driver to work it out.
May 25, 2010 | Motorola Mobility RAZR v3xx Cell Phone
Key noise how to silence on v3xx
go to menu,,,settings,,,sound settings,,,kepad tone.
Jun 17, 2009 | Sea and Sea MOTORMARINE II-EX 35mm Point...
I bought a memory card for my v3xx razor phone with At&t i do not know how to get it to work. I do not have a camera to put it in to take a picture. How can I do it with my phone only?
You must not have a v3xx, because the v3xx uses a mirco sd card
and the slot is next to the sim card slot.Also the v3xx has a camera,
and there is no option to get this model without a camera.
The v3 does not have a memory card, but has camera also.
If you do find the slot,if you have a v3xx,then go to your menu and then open connection, then open,phone status, then scroll down to
storage devices,open it, should be left top button, pick options,now you should see,details,rename,format, format the card, this should allow the phone to see the card. There are some brands that just don't work with a phone. I have always used kingston. I have around 12 different type's and they have always been a great card.
Feb 17, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
I just got a memory card I can't get it to work.
She/He as a i presume have the V3xx.
(this is about the same for all Razrs that take memory cards/Trans flash)
-Menu
-Settings/tools
-System
-Device Info
then to
-Storage Devices
and if it shows up than obviouslt your cards working and the phone knows its there.
if not, a lil trick i found.
Put the transflash card (your lil memory card) into the SD adapter and put it into a camera and take a picture. check and see if the picture is saved on the card. If it is than pop it in your phone and see if you can find that picture. if you dont see it on your camera, its the card.
also if it is listed in your Storage devices.
but for some reason when you take a picture it doesnt save to the memory card?
go into your camera settings and change your storage device to the memory card.
at default it sets your phone as the primary storage, not you memory card.
I hope this helped.
Motorola RAZR V3X
hi, this isn't a solution but it might help explain the possible problem. The v3x camera has a connector in order to connect it to the rest of the phone parts. If that connector is loose or possibly has broke you will get error messages. The only way to know is to have a technician take the v3x apart and check. The V3X is not as easy as the v3 or v3xx to take apart and you must have the correct tools. If needed the camera unit can be replaced so that you don't have to purchase a new phone. If you can find a technician in your area you can ask if he has a v3x that he uses for parts. It would be less expensive. Good Luck.
Jan 12, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Razr v3xx camera screen is green
It sounds like you got it too close to a magnet
Jun 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Razr v3xx celluar
Usually that only happens if the phone was just turned on, so the camera takes time to warm up. Try restarting your phone and try again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
V3xx camera
Have you tried turning the phone off, removing the battery for several minutes and putting the battery back in and restarting the phone?
Jan 30, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola w385 cell phone
my motorola w385 verizon phone quite displaying has white screen , it will not call out . thanks bob borum bobborum69@yahoo.com
Nov 26, 2007 | Motorola Computers & Internet
Motorola Mobility RAZR V3xx Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
