Question about RCA RCR311B Remote Control
Programming Code for a Toshiba TV
I need the code for a Toshiba TV can you help me?
  • 67 Answers
Try these codes:
1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241
Posted on Jun 11, 2008
4 Suggested Answers
  • 5 Answers
SOURCE: need code to program toshiba tv with Direct tv remote
yry 0154 , 0156 ,0060
Posted on Nov 20, 2007
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
Posted on Aug 26, 2008
  • 7 Answers
SOURCE: need code for Advent TV Please...
0176, 0922
Posted on Jul 30, 2008
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
Apr 23, 2010 | Toshiba 24AF42 24" TV
Ihave an old Toshiba tv and a Systemlink 3 romote. I lost the code book, please send me the codes. Thanks
The codes for Toshiba are: 049, 071, 072, 089, 105, 109, 117, 118, 160, 162.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
Good luck and I hope this helps. Thanks for using fixya.
Jan 03, 2010 | Toshiba 27A33 27" TV
Need codes to access TV menus
The solution relies with the remote. press the menu button and use the +/- buttons beside it instead of the volume or channel buttons. This TV was at a work camp in northern Alberta and the instructions were not available. Hope this helps others who do not have instructions available.
Apr 18, 2009 | Toshiba 13A25 13" TV
Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Need code or codes for my Philips Universal Remote to a Toshiba TV
please tell my what code for philips universal remote pm 435s?for my tv sanyo?thanks?
Aug 15, 2008 | Philips PM435S Remote Control
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
Ken
May 27, 2008 | Toshiba 27A34 27" TV
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
RCA RCR311B Remote Control Logo
4,245 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
