Question about Belkin Serial, Parallel, VGA, Network, USB 2.0, DC-in The Hi-Speed USB 2.0 DockStation lets you use just tw
Belkin Easy Transfer Cable: Norwegian Vista connect to English XP
I have old computer with XP in English. I have tried using the East Transfer Cable (Belkin) to move files to the new Vista computer, but I get an error message and the transfer is aborted. Is this because of the different languages? and if so, what do I do?
  • Anonymous Dec 09, 2008
    i am trying 2 move my files from windows xp to vista and recieve an error message
cTech1
  • 66 Answers
SOURCE: Easy transfer Cable
Yes you can do this. Just install the driver on each box, of course, and the units will be able to communicate.
Posted on May 15, 2008
SOURCE: Connectivity problem with Belkin Easy Transfer Cable
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Posted on May 01, 2009
  • 165 Answers
SOURCE: Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Posted on Aug 26, 2009
  • 338 Answers
SOURCE: Transfer XP files to Vista: i am having a
free some disk space by erasing some data u don't need and uninstall some unnessary programs, empty the recycle bin, run a defrag, if that does not do the trick, right-.click onto the hard disk in explorer menu, goto properties and enable the compression for the drive, that will give u space...
Posted on Sep 02, 2009
  • 51 Answers
SOURCE: I have purchased a Belkin Easy transfer cable for
yes you do
Posted on Nov 18, 2009
Help for easy transfer cable
If both computers are connected to your network, you can easily enable sharing of the drive(s) on your XP computer, then connect to it from the Windows 8 computer and transfer the files over the network.
Aug 06, 2014 | Belkin Easy-Transfer Cable for Windows XP...
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Old pc w/disk drive laptop no disk drive.
If both Pc's support the cable and software The cable which I recall was a null modem cable, then yes if your laptop has a serial interface.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Using a belkin easy transfer cable with only one monitor
Hi there. You can use the same monitor for boh the computer (just consider the annoyance of having to go to computer one, do the trick, disconnecting the monitor and connecting it to computer 2 and so on). If, what you want is to extract the files from the old pc because you are going to get rid of it and want to save them, I"d suggest you get a Hard Drive External Enclosure (between 20 and 35 dollars from most places). Connect such hard drive to it and read it via USB interface (or probably E-SATA or Firewire. Depending what do you have in your computer). Hope it helps, good luck.
Jan 05, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Belkin Serial, Parallel, VGA, Network, USB 2.0, DC-in The Hi-Speed USB 2.0 DockStation lets you use just tw Logo
153 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
