2005 Buick LeSabre Logo
Posted on Oct 30, 2010
2005 Buick LeSabre tachometer not responding when engine is running. Tachometer stays on "0" when enige is running. Slight movement as acceleration increases; however needle barely moves as accelleration speed increases "0" to 30 mph.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1498
Points
2005 BUICK LESABRE TACHOMETER DOES NOT REGISTER WHEN ENGINE IS RUNNING. SOMETIMES IT BARELY MOVES, THEN GOES BACK TO 0
SAME CAR HAD SPEEDOMETER QUIT, REPLACED WITH NEW SENSOR, DROVE ABOUT 1300 MILES AND IT QUIT AGAIN. CLEANED THE SENSOR, WORKS OK NOW.
1helpful
The tachometer in the car is very erratic.Sometimes the needle doesn't move when you start the engine, other times it goes a way highin winter it would go all the way around,sometimes it reads right.
If you have no other problems, It is most likely the electric motor on the IP board. Some cases it is the data chip on the board. I have replaced many of these motors over the years.
Tachometer installation
if its a after market tachometer it should have a adjuster to set 2, 3,6, 8 cylinder ,set to suit your engine.
Tachometer
cam or crankshaft sensor, vacuum leaks.
1helpful
While driving my tachometer doesnt go straight to 0 when i stop. It stays around 3/4 close to 1. Is this a concern? 2001 acura cl type s
Hi Eveerei, If you're asking about the tachometer and not the speedo meter, that meter records the engine RPM speed and not the vehicle ground speed The tachometer at idle (when you stop at a traffic light, stop street or any other stop) should record an engine speed of about seven hundred to seven fifty revolutions per minute, at idle. It will increase in relationship to how hard you push your foot on the accelerator pedal. Hope this info helps you. Happy new year and regards John
Got a new tach ,my car doesn't have one, how do I hook it up to a '90 buick 3.3 with electronic ignition? The "instructions" only show how to hook up to standard ignition.
Hello! Your vehicle is equipped with a distributor-less ignition systems; C-31...Does your engine have a "coil pack"? As in two cylinders per coil? The coil pack has a two wire connector at the top which is Ground and +12 volts...At the bottom are 2 connectors...The one on the left is a 4 wire and to its right a 2 wire...the one you are interested in is the 4 wire connector...Reading from left to right...Pin 1=Ground...Pin 2=Reference voltage...Pin 3=6X...
And Pin 4=Tachometer
...Hook the Tachometer wire (probably a green lead) to Pin 4...There is the possibility that the ignition module has a Tachometer input connection...If so use it...If not use Pin 4...
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2helpful
Car: Nissan Maxima SE 1997 tachometer broken
the dash voltage egulator probably went bad. First,check the battery & make sure you have 12 volts,not running. Check it again running & you should see about 14.5 volts. If that's good,I'd replace the guage assembly.
3helpful
2answers
Tachometer is not working
please rate highly if this helps.
Check fuse #37, 10 amp yellow in fuse panel on dash.
The camshaft sensor in the distributor sends the tach signal to the instrument cluster. wire is BU = Blue?
go here for villager help
http://autos.groups.yahoo.com/group/villagerquest/
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
