Question about Back to Basics NS1000 Nutri Source Juicer
Tighten bolt is frozen
How do you losen the tightening bolt when it won't loosen to let the blade loose from the machine?
WD-40 and let it sit for a few hours and it came loose. Had to wash it good before using it.
Posted on Jun 11, 2008
Jack Lalanne Power Juicer250
the power is not properly supplied to blade .....just check whether the connections are proper ....
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
Who might sharpen the shredder blade???
This is a good one because a worn blade
actually causes less vibration. You can
sharpen the blade using a drill. Use a drill
bit about the same width as the cutting burrs
and drill into the face of each one ever so
slightly, almost perpendicularly. Assemble
the juicer and unlock the adjust screw on
the center of the bottom. Turn it clockwise
until the blade contacts the chute, then back
it off a half turn. Don't forget to tighten the
lock nut. I've been using the same blade
for years.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Can't get the wrench in to tighten blade
use a socket with an exyension and rachet.
Sep 04, 2009 | Jack Lalanne Power Juicer 250 Watts
The pusher to push the food into the blade is coming into contact
The blade maybe was not screwed in right. Screw out the blade using the blade tool and screw it back again making sure it is screwed in and fitted in right. Do not tighten too much. It breaks easily.
Jul 10, 2009 | Jack Lalanne Power Juicer 250 Watts
I need to buy a blade tool to remove and to tighten the blade in my Jack Lalanne juicer. Where can I get a replacement?
Just find a big wire bend it and insert both ends on the blade holes. Use leather gloves or cover the sharp blade with a piece of cloth.
Mar 15, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne power juicer classic crescent tool missing
Scroll down a little and theres the cresent tool. It has free shipping and its $7.99
https://www.unitycart.com/pjss/accessories/parts_classic.asp
Oct 18, 2008 | Jack Lalanne Power Juicer 250 Watts
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
Clean the pulp
yes you take it off with the orange handle (separate part)- it fits in two holes and you tighten or loosen it.
Nov 28, 2007 | Jack Lalanne Power Juicer 250 Watts
Back to Basics NS1000 Nutri Source Juicer Logo
181 people viewed this question
Top Back to Basics Juicers Experts
eyecam
David Payne
David Payne
Are you a Back to Basics Juicer Expert? Answer questions, earn points and help others
