Question about Motorola Mobility RAZR V3
Keypad does not do anything
Okay, like others keypad does nothing except turn on after battery removed.
The wireless keypad works for a day or two then stops- we keep resetting it but same problem happens over and over
If you are sure the battery is good and your other remotes work okay I would replace the keypad.
Sep 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My keypad on wireless opener will not work
If the battery is okay and your other remotes still work then the keypad has simply quit.
May 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad doesnt work
not really solve the problem, I believe I still have to go to Nokia Center.
anyway.. I did nothing except I charged my battery (before left two bars), and the problem was disappear by itself...
Aug 24, 2009 | Nokia E51 Smartphone
My keypad wont work except for on/off wotn work
may be your keypad might have worn out or your phonse's software might be under problem. try replacing the keypad in your phone and check it out. it it does not work still then remove the user serviceable parts like panels batteries and clean then using a clean damp cotton cloth.be sure the cloth is not much wet to affect the ic's of the phone.it this also does not work get a pro to attend your phone's software problem,
Aug 16, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Phone turns on fine but nothing happens pushing buttons except power.
If your phone has a keypad lock option, make sure that the keypad is not locked. Refer to the user manual to know how to unlock the keypad.
It is also possible that the keypad is defective and needs to be replaced.
Jerry G.
Jul 12, 2008 | Motorola Mobility i560 Cellular Phone
No response from keypad input?
check your volume keys or any side keys that get stuck... or if you can open your fone check its keypad for any shortage...
Oct 26, 2007 | Samsung SGH-d407 Cellular Phone
My keypad does not work except for the on and off key. I can turn it on and receive calls as long as the phone is closed when it rings. Other than that I cannot access any of the other keys. I tried...
have you tried a master reboot? Remove the battery. Hold the power key down for 30 seconds while battery is out of phone. Replace battery, and turn on the phone. I'm not sure if this will work as it may be a defect of your keypad... however, as long as your phone can be turned on, most wireless carriers have a machine that will transfer your numbers to a new phone. (at least i know verizon does)
Sep 26, 2007 | LG C2000 Cellular Phone
Motorola Mobility RAZR V3 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
