Question about Denon Audio Players & Recorders
Denon amp AVC A10SE After rewiring the speakers and all the other inputs, CD, Phono etc, on start up the amp is shutting down to a red flashing stand by light. Is there a reputable repairer in or around yorkshire?
SOURCE: Receiver shut down only when using phono preamp
Since the protection circuit trips after 4-5 songs at high volume from LPs, it may be that the infra-sonic rumble common to phonographic recordings is driving your amp stages much harder than it sounds like they are driving. You can check this with watt meters for your speaker outputs, or by filtering such extremely low frequencies on the input. If you have an equalizer--especially an old one--it may have an infrasonic filter, or just cut the very lowest frequency available on the equalizer after running your phono pre-amp into the EQ and the EQ into your VCR2 input. This setup will verify if your problem is the infrasonic rumble, but I wouldn't use it as the solution. There are very quiet infrasonic filters available that would work better for the long term. And if you just cut the lowest EQ frequency out, you'll miss some good bass.
Posted on Nov 07, 2006
SOURCE: Denon AVC 3020: Dolby setting
I have similar issue with my 3020...I may break down and buy the service manual.
Posted on Oct 15, 2008
localwonder
  • 6784 Answers
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
Posted on May 21, 2009
  • 4234 Answers
SOURCE: Loud distortion through phono inputs
Phono inputs are designed for turntables only. Any other device will provide too high a signal for that input to handle. The phono input has an extra amplification stage built in. The distortion is because of the high suignal level being supplied to the input. The only way to get this to work properly is to purchase an antenuator which will decrease the signal level to the phono level.
Dan
Posted on Dec 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: Denon avc-a10se just stopped working
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections, too. You need to identify a root cause.
Posted on Feb 05, 2011
I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
Dec 02, 2014 | Denon Audio Players & Recorders
Denon avc-a10se just stopped working and now when I turn it on the light just flashes on and off with out any output. Any ideas ?
Feb 05, 2011 | Audio Players & Recorders
Have a Denon amp (AVC-A11SR) and cannot use the OSD function. Can you give some solutions on how to fix this. Thanks
I have an AVC-A10SE,very similar. The OSD only works via the monitor out COMPOSITE output, so you will need to connect a cable from your amp from this socket to a composite in (yellow) socket on your tv
Dec 18, 2010 | Denon Audio Players & Recorders
I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Jan 06, 2010 | Denon AVR-689 Receiver
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Jul 21, 2009 | Audio Players & Recorders
Denon 2802 amp
Dear Armani,
You cannot put de leads from an MP3 player or your TV into the pre-amplified connection of your Denon,
the phono "stage" is a low input stage, your input from MP3, TV, CD, DVD oscasetteplayer is high output (a 5 to 10 times stronger signal)
Try every other stage like tape 1 or 2, this will work just fine,
succes
Apr 30, 2009 | Denon AVR-2802
My denon avr-a10se stop working. When I start, aftr thr quick intiation the amp shuts itself and the red power light start to blinvk quickly - please help
This unit is in protect mode. This means that a problem was detected in the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common failure parts are the output transistors. These usually run between $5-$15 each. Add in the local labor rate for the total repair cost.
Dan
May 20, 2008 | Denon Audio Players & Recorders
DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
Jan 23, 2008 | Denon AVR-1803 Receiver
You may want to try putting an attenuater in the line with the RCA's to cut the input signal back just a little bit. So you are not driving the amp so hard with your preamp.
Sep 08, 2006 | Denon AVR-2803 Receiver
227 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
