Question about Electrolux Central Vacuum
Dust....dust....dust Hello, I recently bought a house with an older Electrolux Central Vac system. I'm unfamiliar with them, so I'm not sure how to deal with this: I cleaned up some mortar dust with it, and noticed not too long after that when I went into the garage, there was a fog of dust. The hose from the unit is venting into the garage. Is this normal? I have since used it for everyday household cleaning and each time I go back to the garage to a cloud of dust. Is there anything I can do? Thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=662824
Posted by Kitkatman on Jun 11, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that the unit you have may have to be vented outside as I am not familiar with this particular unit, or it could very well be that it is missing a filter or the filter you have inside already is shot and is in need of replacement or on some central vacs there are paper filter that go over the cloth type filter. Again, I am not familiar with this older unit but feel free to contact the Electrolux Factory or Manufacturer and give them the model # and the serial # for the unit and they will have a breakdown of if it should be vented and what type of filtration it should be using. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
Central Vac Dust Care 3000C - My system will not turn off when I unplug the hose. I also tried unplugging the low voltage wires from the unit and it will not turn off . Any thoughts?
A hanging relay, put a piece of paper between the magnet and the actuator, it releases quicker. Or there is a short in the wire, measure if there is a voltage over the wire, if not there is a short somewhere, good luck!
Dec 05, 2011 | Central Vac Dust Care 3000 Bagless System...
Central vac... picked up rings, how do we get them back
Bummer! The rings are still there. They will either be lodged in the pick up nozzle or in the bag itself. Take the bag out, this will be am out door job due to the dust present. Open the bag and carefully search through the debris. They will be there. Don't throw that bag away until you find them.
Zashiban
Jun 23, 2010 | Electrolux Harmony Canister Vacuum -...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 1590 not turning on
TRY JUMPING THE CENTRAL VAC INLET WIRES AT WALL! IF COMES ON SOMETHING IS MISSING ON HOSE TO WALL CONNECTION. MOST HAVE A METAL RING TO ACTIVATE THE INLET DOOR WHEN HOSE IS CONNECTED.
Dec 12, 2009 | Electrolux Vacuums
I have two Electrolux Central Vacs. One is not working. Is there a reset button
If this is a CENTRALUX metal bodied 1590 series vac vac there is a reset breaker on the side of the motor housing of the vac. Depending on the age of the vac there is also a filter lockout switch . If you are using a cartridge filter and it is misaligned and drops down the switch will shut the vac off to prevent motor damage. Check those two items. The internal filter must be fully inserted so its twist lock/washer device can rotate holding it up in place. Then take a pair of insulated pliers and short across the low voltage terminals where the wiring system enters the top of the vac . If the vac starts, it is fine. If not your problem lies in the motor , the relay or the filter lockout switch.
If you have a plastic bodied Electrolux, a recent model the test procedure is the same but there is not the same lockout for the filter
Next test the nearest inlet in the house. If it fails to start you have a break in your internal wiring, possibly at a connection or a an inlet which may have a loose wire connection behind the wall. Post back with your results and if you have more questions. If so post the model #
Oct 28, 2009 | Electrolux Central Vacuum
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
http://centralvacproducts.blogspot.com/2009/01/how-to-unclog-central-vacuum-system.html
Oct 24, 2009 | Electrolux Central Vacuum
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
Do you know what a filter bag looks like in a central air vac system?
The unit displayed is a Beam Electrolux central vacuum power unit. It has a 15litre dust bucket which does not need any dust bags.
If you take the bucket off you will notice a white shiny weighted bag hanging down. This is the filter. The good news is, it is a self cleaning filter.
Dec 03, 2008 | Beam Industries 2775 Serenity Plus Central...
Dust blowing out of hoover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618781&thid=617336
Dust blowing out of Hoover
Posted by Lunagus on May 23, 2008
When I start up my year old Electrolux Loopie Petlover vacuum a large amount of dust comes out of where the HEPA filter is - can you suggest reasons?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Upright 014T XL Pro 14 Upr Vac
In answer to your question, if the HEPA filter is leaking then you should replace it because it has lost it’s filtration – but my question is – is it on the Oreck, Hoover or Electrolux --- all three have HEPA filters and needs replacing and to make sure that the HEPS filter is installed correctly or other wise the filter will leak and if that happens then contact your local vac dealer in your neighborhood. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Go Ahead. Use Us.
May 23, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Vacuums Logo
125 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
