Question about InFocus IN36 Projector
Infocus Projector Not working
Dear Concern,
We are having in focus projector in our office, since one week we are trying to get in touch with your local customer care persons for repair the In focus Projector. Till date the problem not rectified. And response is very very bad. Request you to look into this on high priority and do the needful.
Thanks in advance
with best regards
Srinivas
GVK Biosciences Private Limited
#210, 6-3-1192, Kundanbagh,
Begumpet, Lifestyle Building,
Hyderabad - 500 016
Mobile # 9959 555 2 27
Telephone # 6692 9999
Direct # 6692 9942
SOURCE: LP 640 projector not able to display 1080p
The specs of the LP640 show that the maximum resolution it can handle is 720p. You are trying to make the projector do something it cannot handle
Posted on Jun 06, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Posted on Sep 04, 2009
projdoc
  • 2237 Answers
SOURCE: I am looking online for a Service Manual to
you won't be able to get one for free. infocus service centers are prohibited from releasing that info. if you want a user's manual, try www.projectorcentral.com
Posted on Dec 11, 2009
  • 269 Answers
SOURCE: jammed projector lens infocus lp770
get a wide bladed flathead and find the widest part of the **** between the focus ring and zoom. work the blade like you are trying to widen the the slot, do this all the way around till it pops back into place.
Posted on Jun 01, 2010
  • 269 Answers
SOURCE: Infocus IN10 projector is flickering
it is likely a grounding problem associated with the connection of the power supply to the main board.
Posted on Jun 20, 2010
Infocus 3916 Projector goes in and out of focus. It is a little less than 2 years old. Any suggestions for a solution?
Many of these projectors have a manual focus, and an auto focus. Make sure the auto focus is turned off in the menu options.
Then make sure the manual focus is not moving on it's own from vibration of the cooling fan. You can check this by manually focusing the projector, then taking a marker and marking a line on the focus wheels. If the projector goes out of focus, check the line you made and see if it has moved, if so. Your projector is going out of focus from vibration of the cooling fan, or the surrounding environment.
If your projector is mounted to the ceiling you can add a couple of rubber washers between the projector and the mounting bracket to cut down on vibration.
If your projector is sitting on a desk / table / ground, you can use foam padding to keep it from vibrating.
another solutions would be to temporarily tape the adjusting knobs while the projector is in use.
If your projector has a protective cap that is put on the lens when not in use, this will also push the lens out of focus, and will need to be re-adjusted each use.
Nov 20, 2014 | InFocus Office Equipment & Supplies
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Jammed projector lens infocus lp770
May 31, 2010 | InFocus LP70+ Multimedia Projector
I am trying to set up an InFocus LP400 projector with my computer. I followed the instructions using the CableWizard Lite cable for my laptop pc and get no projected image. I used the suggested port...
start the connecting all over again, by following the steps below:
1. Turn your computer off.
2. Connect the cable from the computer to the projector. If you want to have your monitor to be hooked up as well, connect a splitter to the video out port (DVI or VGA). You can also just hook the projector up to the second port on your video card (If you have one) or if you have a laptop, you can connect to the video out port on the back.
3. Turn the computer on and boot into your desktop.
4. Turn on the projector. Most projectors have an auto detect function, that will detect a video signal and auto configure the projector to display that signal. If you have a laptop, you have to hit a function key to activate the second display. Usually this is FN Key + F5 or one of the F Keys across the top of the laptop keyboard. It looks like two squares, one empty and one with something in it.
5. Adjust the focus, brightness, contrast, and color on the projector.
6. Aim the projector at something white. Try not to aim it at something highly reflective.
7. Step back ... Load up your favorite game or video ... and enjoy.
Your project should work, after following the above instruction.
Good luck.
Apr 07, 2010 | InFocus LP 400 Multimedia Projector
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
My In Focus
if the lamp is relatively new, the colorwheel might be coated with dust. the heat bakes it on. you can try to clean it, but you might end up having to replace it. try av solutions in ny. they're pretty good.
Nov 02, 2009 | InFocus ScreenPlay 5700 Multimedia...
Does anyone know of a repair/service center in NYC for an In Focus LP70 Projector?
there's one in rochester, ny. av solutions. i believe they are an authorized infocus service center. www.avsolutionsny.com
Jun 29, 2009 | InFocus LP70+ Multimedia Projector
REMOTE
good luck. infocus has nothing having to do with any of the lp4xx series. they don't even have lamps. try ebay.
Apr 11, 2009 | InFocus LP425z and LP435z Replacement...
In focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Jan 20, 2009 | InFocus LP640 Projector Multimedia...
Hitachi cp x880
well lens assembly has to be repaired. try avalontc.com
Jul 21, 2008 | InFocus LP70+ Multimedia Projector
InFocus IN36 Projector Logo
76 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
