Question about Sony VAIO RB30C (VGCRB30) PC Desktop
VAIO Help Hi Dilip, Thank you for the help on VAIO. Can you givememoredetails like ifVAIO will work with all functionality ofaudiobuttonsthat are thereon the keyboard, camera button, displaybuttonetc. Do u think it would be worht spending 6k more to get XP on my laptop?
    President:
  • 1,257 Answers
Actually drivers are needed for that ,check your device manager for any yellow icon...if you find any yellow icon that means there is a drivers issue and it might be the reason that your audio buttons are not working or keyboard ....
Here is the link for xp drivers
http://www.sony-asia.com/subtype/usefulinfo/asset/216869/product/vgn-cr22g?site=hp_en_AP_i
Ya definitely if you are uncomfortable with vista you can install xp ,its good ,i too use xp .but i have installed both operating system xp and vista ....so if you want to install xp go for it..you can also install vista after you have installed xp .but it is not possible to install xp after vista ...so first install xp and than vista only if you want...........and if you need any help after installing xp let me know...
_____________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating if the solution is helpful.
Thanks for using fixya support..You have a wonderful day
......please don't forget to rate this time...
Posted on Jun 11, 2008
Driver sony vaio pcg 91211m
Hi, I need to sony vaio PCG 9111m model drivers. Who is help me?
my contact addres: drihsany@gmail.com
Thank you for your attention.
Dec 19, 2012 | Sony VAIO VGN-FE550G Notebook
Hi all, I need to join skype for a college class and my Sony Vaio RB60 series will not recognize the microphone/headset I bought. It is supposed to be compatible with the XP on my Sony and the plugs...
It sounds to me like your sound card drivers are missing. var fctb_tool=null; function FCTB_Init_c43b474a396a4bcbab93488a2dfd78d2(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_63d47478e44c4b938697691dc95fbef0(t) { fctb_tool=t; start(fctb_tool); }
Jan 24, 2011 | Sony VAIO RB60G (VGCRB60G) PC Desktop
Hi fellas, i'm having trouble with my vaio pcg-k47. the fn key is on all the time, and instead of having letters on the key board, there are some that are wr5ting nnumbers. can u help me fix that? Can u...
Press the Function (Fn) key again to deactivate it.
Please check if the "NUM LOCK" is enabled. If it is enabled then press it to disable to resolve the letter/number key issue.
You may disable the Function key by removing the VAIO Event Services Utility or HKSERV Utility from the Startup.
1. Click on the Start, select RUN, in Run command type: msconfig and press the Enter key.
2. In the MS Configuration Utility, un-check the VAIO Event Services Utility or HKSERV Utility and then click on Apply then OK.
3. Then, restart the Computer. This will disable the Function key in the Computer.
Good Luck!!!!!!!!!
Nov 18, 2009 | Sony VAIO PCG-K47 Notebook
Sony vaio vgn-nr160e with vista, function+ keys wont work
To enable the Fn keys functionality, you need to install the "Vaio Event Service" and "Sony Utility Series"
They are available to download as part of a package from the Sony website. Here is the link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR160E&upd_id=3262&os_id=28
Regards,
Purito
Oct 18, 2009 | Sony VAIO VGN-NR160ET Notebook
Vaio Care & Vaio Sat Survey.exe has stopped working
Hi guys. I'm a Technical Support Agent for the Sony VAIO.
Please open the C: Drive > Programs x86 Folder > Sony > satsurvey or survey, then, delete the vaiosatsurvey.exe File from there. It should successfully resolve the issue. Hope it helps. I took remote sessions and resolbved many issues.
R30
Jun 11, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Sony vaio touch pad not working.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
Oct 28, 2008 | Sony VAIO VGN-SZ460N/C Notebook
I have a sony vaio lab top and a vga in to rca cable and a magnavow 32inch hdtv moldel 37mf33id and i can't get it to work togethere.help please?
Assuming that the VGA to RCA cable/adapter is functioning correctly, then what might be required are:
  • initially lower the screen resolution of the Sony Vaio laptop to the lowest possible;
  • press F? key to cycle on the display choices, LCD, LCD+TV and TV only. The F? key would be the one with the small monitor icon.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Televison & Video
Region Codes for Sony DAV-DZ270
I bought a Sony home theatre DAV-DZ270 region 4, can you please help me to make it multi-region.
Kind regards,
DILIP
Aug 24, 2008 | Televison & Video
Hello Boss -Ineed your help regarding chat session
Dilip welcome to fixya.
See there are very less chats sessions each day so you have to atay online signed in with your chat software all most all the time so that you can get one.All you have to do is just be signed in and have alot of patience for a chat to popup.
Apr 28, 2008 | Microsoft Windows XP Home Edition
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
93 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
