Question about NAD C320 2-Channel Amplifier
The right channel on my NAD intergrated amplifier C320Bee no longer works.
The right channel on my NAD intergrated amplifier C320Bee right channel no longer works. Verified it is not the speaker or cable and checked all the fuses with contuinity tester and swapping known good ones.
  • 682 Answers
If you did test for your cable and speaker and you find it fine-your problem will be in output stage of your amp and needs aid of service center.
Posted on Jul 15, 2008
Can you still get a new volume control pot for a nad 310 intergreated amplifier
I don't see why not. Just get the value of the pot off the numbers on the back of it or measure it
Aug 30, 2016 | NAD Audio Players & Recorders
Nad c320bee keep over heating
Hello
Disconnect all speakers and switch ON the set without any input connected, and see whether it heats up. A moderate heat is permissable, but should not over heat. If it overheats without any load or input connected, the set need service. OK.
Jan 19, 2012 | NAD Audio Players & Recorders
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
I run a sub and two sets of speakers on speaker B of my NAD C740 through a speaker selector. I think there has been a short circuit caused by the + and - wires touching. The left channel no longer works on...
Check that both left and right channels work on A speakers. If they do, the amplifier is probably good and your problem may be outside the amplifier. Try swapping the left and right speaker connections at the back of the amp to see if the problem changes from left to right. this would tell you if the problem is in the amp or out to the speakers. Hope this helps
Jan 04, 2011 | NAD C740 Receiver
Nad c270 power amp transfomer hum
if the hum is in the sound output you have a blown power regulator
Mar 31, 2010 | NAD C270 2-Channel Amplifier
NAD C320 BEE - goes silent. Only yellow light.
Just came accross your post accidentically, while reparing my own C320BEE. May be it 's too late for you now, but it could help others: I had the very same symptoms as you described and after a long search found out that the trouble was R45 in one of the 18V regulators. (R45: 33 ohms 1/2W fuse resistor, situated more or less half-way between the two "metal towers" on the main board. Replace by a somewhat stronger type 1W or so.
Likewise R46.)
Dec 23, 2009 | NAD C320 2-Channel Amplifier
Dear sirs, I have NAD
2 x 25 Watts continuous power (8 ohms)
Jun 23, 2009 | Audio Players & Recorders
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Connecting sub with nad c320bee
pre out from nad---------to 2 rca input in sub.
Jul 22, 2008 | NAD C320 2-Channel Amplifier
Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Jan 17, 2007 | NAD C350 2-Channel Amplifier
NAD C320 2-Channel Amplifier Logo
285 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
