Question about Pioneer CDJ-800 Turntable
Cdj 800 error 8301
I keep getting this error on my cdj. a disk is inside of it and when i turn it on, it reads error 8301.
thx.
  • bluntox Jun 16, 2008
    same problem as described but cannot eject disc.
  • Anonymous Apr 18, 2009
    Tenho o mesmo problema com cdj 200, so que o ele não esta mais lendo nada só erro 8301.
  • 3 Answers
Listen to solution #1. The man knows what he's talking about. Replacing the laser pick-up assembly in the machine is not an easy thing. If you are not electrically talented in fixing things, you WILL mess it up and end up damaging the part and/or player. Read what i have to say about the problem. If it still deosn't work for you, then look for a place that will repair the player for you-
It sounds like you might have problems with your CDs. If you are burning CDs on your computer to play in the CDJ, you need to remember that it will only play audio (wav), or MP3 files. Also, blank data CDs are cheaper that buying audio / music CDs. When you burn your CDs to play back on the CDJ, you have to be sure to burn them as wav or mp3. AAC, MP4, OGG and the other formats will not work in the player. When you burn the CD, ALWAYS burn at a slower speed than what the computer will automatically burn at. You will have to manually set the speed yourself.
Personally- when i burn my tracks CDs for my CD book, I use trusted name brand blank data CDs such as Memorex, Sony, TDK, Fuji, Imation. I burn them as AUDIO ONLY. To avoid any reading mistakes that could happen with any given CD player, i NEVER burn track CDs as mp3. When i burn the CD, i set the writing speed to 24x, 30x, or 32x. I recommend that you DO NOT burn your CDs at any speed faster than 32x. From my experience, that is the fastest and safest burning speed. If you do these things, and you still have problems with the E-83 02 code, then it will only have to be the kind of CDs your using to burn, or your CD burner in your computer. Notice how i didn't mention Maxell CDs up top. 3 months ago, i bought 2 spindles of Maxell data blanks on sale for $9.99 each. I was happy i got them that cheap, but the CDs themselves were no good. Recording everything the way i do, they had popping noises and scratching sounds through-out the disc. I gave the spindles to my neighbor. He was happy to get blank CDs free. I WILL NOT say that Maxell makes a bad product: I still record on cassettes and Maxells are one of my top 3 choices for blank chrome tapes. But the discs i bought were just a bad batch. Maxell is still a trusted name for blank tapes with us older DJs that started out with recording on tapes before the CD format became way cheaper and affordable.
Try burning your discs as audio only, and burn them at 24x, 30x, or 32x ONLY. Buy better brand name data CDs, and you should have no problems. If you use my method as an example, and you still have problems, then you need to get a new CD burner for your computer. They are always cheaper at Staples or Office Depot. Hope **** works out for you : D
Posted on Nov 29, 2008
  • 8,596 Answers
Error Code
E-72 01
E-83 01
E-83 02
E-83 03
E-91 01
Description
Player unable to read TOC data.
Disc is rotating, but rotation cannot be ascertained.
Player unable to play back currently inserted disc.
Mechanical operation has failed to complete within
specified time interval.
Possible cause and recommended action
Disc is cracked.
= Recommended action: replace disc.
Disc is soiled or dirty.
= Recommended action: clean disc.
If other discs play normally, the problem is with the disc itself.
Dust or some other form of foreign particles have found their
way into disc insertion slot.
= Recommended action: remove dust or other foreign particles.
Error Type
TOC READ ERROR
PLAYER ERROR
MECHANICAL TIME OUT
Posted on Jun 11, 2008
  • 68 Answers
Sounds like a laser pick-up fault,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Posted on Dec 03, 2008
  • 515 Answers
If after you replace your disc, and determine that there is no foreign object in the tray obstructing anything, and you still get the same problem, the issue is probably the traverse assembly, which is essentially the optical eye unit. It will more than likely need to be replaced. Unfortunately, this is not an easy repair, and I would suggest taking it to a qualified service center for repair.
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
Posted on Jul 12, 2008
Pioneer CDJ 100 Error E-8301 by every CD
I don't understand your question...please make it clear.
Feb 26, 2015 | Pioneer CDJ-100S CD Player
Error 8301 comes every for any cd.
8301 error is an error during startup. It should clear if you press the eject button, which could mean something blocking the track or sensor. or call 1-800-872-4159
Sep 23, 2013 | Pioneer CDJ-200 CD Player
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
My cdj 800 is not reading cds.
Hii,
Please try to clean laser and compartment of your CDJ. Also, make sure if you can open ur deck and fix it again. If it does not work and u get any error msg too. pls let me know.
I hope this will work.
thx
djajay
Aug 08, 2010 | Pioneer CDJ-800 Turntable
There is a disk stuck in my pioneer cdj-800 on the track display it say 00 e-9101 and i cant eject from deck
hii there,
Please look bottom (turn ur CDJ 180 degree) there will be a pin
to eject the disc from ur CDJ. Also make sure when u do it ur CDJ must be turn off.
thx
djajay
Aug 06, 2010 | Pioneer CDJ-800 Turntable
8301 EROR MECHINCAL NOT WORK
Hii,
This is a player error, try to clean up the laser and compartment of
CDJ. Also, look at ur disc if u play MP3 these must be new, not much scratched
thx
djajay
Aug 04, 2010 | Pioneer CDJ200
Wwhy 9101 in display? i am brasilian.
hi 9101 is mechanical time out error. When u insert disc to ur CDJ
and that is not able to read disc within the given time then
error 9101 display.
Please try to clean laser and compartment of your CDJ, their may be dirt, dust inside it. I hope this will help.
thx
djajay
May 25, 2010 | Pioneer CDJ-100 Turntable
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
I'm having a problem with my CDJ 800. Loading ejecting
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
3,727 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
