Question about Whirlpool Duet GHW9150P Front Load Washer
COntrol Lock is on and it willnot reset
Unplugged and I also held the button for 3 seconds
    Genius:
  • 1,554 Answers
Press and hold the signal level 10 seconds
Posted on Jun 13, 2008
Maytag refrigerator MFI2568AES. "Change Filter" light will not turn off. Held down filter reset for 3 seconds - did not work. Held down the light and lock buttons for 3 seconds - did not work. Wha
Hello Don;
My name is Peter. I am a retired field service refrigeration technician.
Your filter reset is just a independent timer set for six months. It is not tied into your water filter. You should change your water filter when your water dispenser flow is slow and/or you start to get small ice cubes. Depending on the usage, your water filter can last 18-24 months or more.
Unplug your unit for about 10 minutes to let the unit power down, then plug it back in.
Dec 31, 2014 | Maytag Refrigerators
My washer is locked. I unplugged and plugged bach
holding the end of cycle button is the control lock,not the door lock. Check to be sure that the control lock light is off--if not, hold end of cycle button again till control lock light goes off.
I've given up on the door lock after a few years fighting it, and researching. There is a solution on fix-it that may work--if it is computer(mother board I think they call it)--and not door lock mechanism. I've read many posts from duet owners that replaced door lock mechanism just to have it be a soldering problem with the "mother-board" that makes the machine "think" there is a door lock failure.
Here is link to a fix-it post I used today to get my machine open and retrive clothes it has held hostage for several days:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet dryer won't go off the control lock. I've held the button down for longer than 4 seconds, unplugged the machine and still nothing??
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)()(^$#
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet control lock light is on and the machine will not do anything. I have held the end of cycle button for several seconds and even turned the breaker of all night hoping to "reset" it.. no...
Jul 29, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a whirlpool duet dryer - the control lock button is engaged - I've held down the end of cycle button for three seconds + plus it will not release. What next?
Jun 13, 2009 | Whirlpool ET8CHEXSQ Dryer
The dryer's control lock light stays on and can't start the dryer
I held the "End of Cycle " button for 3 seconds and the dryer reset itself. Pretty simple.
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Control lock light will not go off on duet
there is a button marked "control lock" hold for 3 secs and will release, its the far most right bottom button
Nov 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light stays on.
Carefully and slowly look for a button, I dont remember which, but there is a button that duels as a child lock if held for three seconds, find this and hold for three seconds to fix:)
Sep 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
