Question about EliteGroup P4VMM2 Motherboard
P4VMM2 "Checking NVRAM"
Hi! I have a problem with my computer. Every time I turn it on there a message "Checking NVRAM" during booting. And it stays there and won't continue to detecting the Hard Disk, etc... Any help would be very much appreciated. Thanks!
  • kukuyi Jan 27, 2009
    i have the exact problem
  • 2,794 Answers
Do you know where the lithium battery is located on that motherboard?
Replace it and reset your BIOS.
Posted on Jun 11, 2008
With which button do i reach safe mode
During the boot process you will press F8 to bring up the safe mode menu. You want to press F8 after the computer posts and just before the windows screen comes up.
Also you cannot press F8 too many times so when in doubt just keep pressing F8 after you turn the computer on until the menu comes up.
This is what you should see if you have successfully pressed F8.
Apr 27, 2014 | EliteGroup P4VMM2 Motherboard
When i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging...
Sounds as though your new RAM may not be compatible with the ECS.This is most certainly the case if the system boots correctly with the old RAM back in place.You may need to check the specs for this mobo on the EliteGroup website to find out what RAM is compatible.
Nov 07, 2009 | EliteGroup P4VMM2 Motherboard
i think u are trying to upgrade ur ram with ur existing ram, if this then plz check ur old ram frequency and then select another ram with same frequency, means u have to install rams with same frequency. i hope u can understand what m i saying.
Nov 07, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Checking Nvram
You could have had a corrupted update. Do you have the CD that came with the computer? There is a BIOS restore utility on it. Download the 1st BIOS version from the website and see if you get the same results.
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
Booting problem
Do you know how to get into the BIOS setup? You can set it up for default in the BIOS settings. If it isn't saving them after restarting your computer, you should replace the battery to the motherboard.
Like cmos battery problem.... checking nvram
That is what you are supposed to do move jumper 30 seconds and replace back to original
your BIOS should be set to default check that you have correct ram inserted into M/board
Aug 16, 2008 | EliteGroup P4VMM2 Motherboard
When turning on my macbook pro
Please clean-up the RAM modules wiping it with a dry cloth and re-insert it back into its slot .
May 06, 2008 | Apple MacBook Pro Laptop Computer with...
Cmos
Hi stan_z4, do you have the manual for you're board?
I'm showing the P4VMM2 is made by ESC = EliteGroup.
Which is not listed above (Intel D845EPI).
If you do have the board EliteGroup P4VMM2 than turn to page 11 in the user manual. The jumper for the cmos/bios JBAT1, Pins must be set to 1 & 2. If JBAT1 is set to pins 2 & 3 you will reset you're bios every time you boot up.
Don't have you're manual? Click on the link.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Mike
Apr 28, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Nvram
Hi, This message "Checking NVRam" is part of the BIOS/CMOS POST even before Windows loads up. Offhand two things you can try: 1. Do a CMOS reset by temporarily moving the jumper near the battery to the opposite pair or by removing the Lithium battery for a couple of minutes or as prescribed by your motherboard's user manual; 2. If #1 is a no go, perhaps you should consider flashing your BIOS. If neither works out, it is possible that you have a hardware/motherboard problem and would require replacement. Hope this be of some help/idea. Post back with your motherboard brand/model, how things turn up or should you need further information. Good luck and kind regards.
Sep 14, 2007 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
329 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
