Question about Fuji Discovery 185 Zoom 35mm Point and Shoot Camera
Fuji 35mm Camera (Model DL-400)
FixYa Support instructed me to contact you and said that if I couldn't find my exact camera model listed, I should find the product page of a similar product to report my problem on so here goes...
I have an old 35mm Fuji camera - Model DL-400 that I purchased in March of 1991. The camera had been working perfectly fine until last October. Someone gave me another 35mm camera that I thought I'd try out. Because I wasn't going to be using the Fuji for a while, I took the battery out. There was no film in the camera either. A couple of weeks later I wanted to go back to using the Fuji so I put the battery back in and loaded a new roll of film. The camera made its usual sound of the film loading, but when I went to take a picture, the shutter wouldn't trip. I tried it a couple of times - still nothing. I checked the battery to make sure it hadn't expired and it hadn't but I put a new one in anyway. Still nothing. I tried hitting the mid-roll re-wind button and again it made the usual sound of the film rewinding, however when I opened the camera back, the film had not rewound. I closed the back of the camera and the entire roll then rewound into the cannister. I tried another new roll of film, again it sounded like it was loading, but this time I went into a dark room, opened the back of the camera and I could tell the film had not loaded. When I closed the back of the camera, that entire roll of film again rewound back into the cannister.
According to the troubleshooting section of the manual one "Fault/Problem" is that the exposure counter blinks (which mine did), the shutter won't trip (mine didn't) or the loaded film returns directly into the cartridge (mine did). One of the "Possible Causes" was that I unloaded a partly used roll of film without winding it back into its cartridge. Although I didn't do that (remember I just took the battery out of the camera while there was no film in it), I tried the "Remedy" for that problem which was to close the camera back then press the Mid-roll rewind button (it said the camera motor will run for five seconds (which mine did). It said to repeat this until all the marks and signs in the LCD showed up simultaneously (which mine did) then closed the lens cover. I did all of that but still nothing. Any suggestions. I realize this is an old camera, but I REALLY like it and although I do have a digital camera, I still prefer using the 35mm at times.
Dawn
    Scholar:
  • 185 Answers
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Posted on Dec 13, 2008
SOURCE:
How do I fix the tele/wide button?
You'll probably need to take it to a repair expert because the internal component needs to be replaced. Because of the age of the device, lack of replacement parts, it will be hard to find someone who is capable of doing it. Might want to consider an upgrade/replacement.
Jun 23, 2015 | Fujifilm Dl-400 Tele 35mm Film Camera Auto...
Fotonex 4000sl
The Fotonex 4000sl takes APS film cartridges.
You can find out more about the camera here:
http://camera-wiki.org/wiki/Fujifilm_Fotonex_4000ix_SL
Although branded Fuji, it was made by Olympus and is identical to the Olympus Centurion.
The Fuji version of the manual can be purchased here: http://www.oldtimercameras.com/stock/Model.asp?Model=8644&ModelPage=true
The manual is no longer supplied for free by Olympus as the camera is 18 years old.
Nov 09, 2013 | Photography
What film to put in a fuji DL-95 camera
The DL-95 uses standard 35mm film. You can use slide film or negative film (prints). You can use color or black-and-white. It's your choice.
Jan 04, 2013 | Photography
I need a manual because I don't know how to change from ASA 400 to ASA 100
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 21, 2010 | Nikon FG 35mm SLR Camera
My brother's Fuji Discovery 1000 35mm Camera met with a small accident. The latch on the cover is broken. I don't know how old the camera is, but would like to know if it can be fixed, and if so, what is...
Parts are no longer available, and like almost all 35mm compact cameras (and many SLR's), your brother's camera is utterly worthless so repairs are totally uneconomic to repair unless you can fabricate a replacement latch yourselves.
Although this may sound gloomy, it's not. The silver lining is that you can easily find a similar or better model on your local FreeCycle or Freegle groups for zilch. There are millions of perfectly good 35mm film cameras lying unused at the back of peoples cupboards and drawers and the majority of owners know they're near worthless so haven't even invested in the replacement batteries that many need.
May 27, 2010 | Fuji Discovery 1000 35mm Point and Shoot...
How do you delete multiple pictures on my camera
I think you've listed this under the wrong category.
You cannot delete multiple pictures on a Canon EOS Rebel XS 35mm SLR unless you do it the same way as on ALL film cameras: remove the film and pull it all out of the film canister. But this destroys all images.
If you're asking how to do it on a digital camera the answer will depend upon the exact make and model and I respectfully suggest that you repost your question under the correct subject heading with the necessary details.
Jan 30, 2010 | Canon EOS Rebel XS 35mm SLR Camera
How do I change the ISO/ASA and question on flash
Here's a link to a downloadable instruction manual for your camera: https://georgetownphoto.fotosource.com/downloads/camera_manuals/Fuji/DigitalCameras/FinePixS5100-S5500.pdf
Jul 03, 2009 | Fuji FinePix S5100 Digital Camera
Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
Jun 15, 2009 | Nikon N70 35mm SLR Camera
Repair of a Fuji 35mm Model DL400 camera
clean all the battery contacts and be sure the batteries are good. use enough film leader so that the drive sprocket can grab the film when the film door is closed. there are no new parts for this model fuji.
Jun 14, 2008 | Photography
Fuji Discovery 185 Zoom 35mm Point and Shoot Camera Logo
192 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
