Pavillion DV1000 will not boot
The laptop will not boot, no power. I have followed the HP troubleshooting guide, reseated the memory module and that seemed to work for an hour or so. I moved the HP and it shut down. Now it will not power up at all. Would like any suggestions b/4 taking in for repair.
Lots of people are experiencing problems with the pavillion dv series. My laptop shuts down without any warning, but someone wrote in a forum that if it shuts down on the battery you have to plug it in the AC power to restart it. My battery has issues since I got the laptop, so I can`t tell that by own experience. Hope its not the same issue, because I`m researching a solution for about a year now and didn`t find any besides buying a new laptop.
Posted on Aug 27, 2008
  • 2,022 Answers
Just make sure the power cord is connected properly and u getting power on adoptor. still u r not getting the power then remove the battery and just on power some time it is happen bcoz of battery fault
Posted on Jun 11, 2008
  • 2,785 Answers
May be two things 1. your powersupply unit is gone or 2. your motherboard
Hp pavillion dv9000 power input jack lights up and power is getting to mother board but it wont power up
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 21, 2012 | HP Computers & Internet
My laptop is not booting. Lights are blinking.
I will show you a guide on how to reseat your memory. This is my first troubleshooting procedure on a situation like this:
Mar 30, 2011 | HP Computers & Internet
When i turn on my computer hp dv2000 i only hear 1 long beep followed by 2 short beeps..but theres no display.
Common solutions for issues that cause blinking LEDs or beep tones
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection.
The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
NOTE: Removing and reseating memory modules requires the use of tools and the partial disassembly of the computer. If you do not feel comfortable doing this work yourself, take the computer to an authorized retailer for technical service.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors. To reseat the memory module, take the memory module out of the memory slot and then put it back into the slot to get a better connection so that the computer can recognize the memory.
The memory module compartment on most notebooks is located on the bottom of the case, however, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules:
Step 1 - Remove the electrical power
To remove all power from the computer and prevent accidental damage to the electronic components, do the following:Turn off the computer by pressing and holding down the Power button for about 30 seconds. Unplug the AC adaptor from the notebook.Slide and hold the battery release latch to the unlock position.Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
Remove the memory module cover on the bottom of the notebook.1 - Loosen the compartment's retention screws2 - Lift up and remove the memory compartment coverRemove the memory modules from the memory slots.1 - Pull the retention clips away from sides of the memory module2 - Gently pull the module out of the memory module slotCAUTION: To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.1 - Align the notched edge of the module with the tab in the slot.2 - Firmly press the module into the slot. 3 - Pivot top edge of memory module downward until retention clips snap into place.After reseating the memory module, replace the cover over the memory compartment before restarting the computer.1 - Align the cover tabs2 - Tighten the memory compartment cover screws
Step 3 - Replace the electrical power
When troubleshooting problems, use only the AC power to perform the tests. After the problem is resolved, you can turn off the computer and insert the battery into the notebook. Plus the connection from the AC adapter into the notebook, and then connect the AC adapter to a working power supply.Perform any tests to verify the computer can startup and run in the Windows operating system.With the computer turned off, push the battery into the base enclosure until the retention clips click into position.
If the computer can access part of the memory, it may be possible to access the BIOS Setup Utility display and perform a memory self test to identify other memory issues. If the computer cannot boot to the BIOS Utility, try removing and reseating the memory and the hard drive, and then repeat the following steps to perform the memory self test.
1.Plug the AC adapter into the computer.
1.Turn off the computer.
1.Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
1.In the BIOS Setup Utility, use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Diagnostics .
1.Use the Down Arrow or Up Arrow keys to select Memory Test .
1.Press Enter , and then Yes to perform memory test.
1.After test completes, press f10 key to Save and Exit , and then press Enter key to Exit Saving Changes? .
If the test fails, one or more of the memory modules may not be seated properly. Check for and reseat loose memory modules.
What to do when the computer starts into Windows normally
After you have completed the troubleshooting process and your computer has booted normally into the Windows operating system, you should:Run HP Assistant to update HP software and drivers. Run Windows Update to update operating system and software.Run anti-virus program to remove any virus.
Aug 13, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
May 26, 2010 | HP Compaq nx6110 PC Laptop
HP Pavillion dv6000 screen will not come on all the lcd hookups are fine just a blank screen any tips on what to do?
put the laptop on a lcd monitor.If work , your laptop lcd is dead ;if don't work your video proc is done.
But first of all change the memory module .
Jan 09, 2009 | HP Pavilion dv1000 Notebook
Upgrading my laptops memory
If it has two simms slot available you can, but I suggest better use the 1GB
Dec 13, 2008 | HP Pavilion dv1000 Notebook
No power - no boot
no power no boot can be indicative of a motherboard failure or could also be the memory. try removing all the memories, hard drive, the optical drives and all external devices connected to your computer. if you get to hear a beeping sound .. your in luck your motherboard is alive and just need to isolate which among the remaining pieces is causing the no power.
Jun 14, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 PC Notebook
Have you followed the recommendations on HP SITE
If the screen is blank they suggest disconnect the power, battery, and reset the memory modules.
May 25, 2008 | HP Pavilion dv1000 Notebook
Power LED flashes three times-no boot
Try this. Power down. Remove the battery. Remove the memory. Replace the memory. Replace the battery.
Try to power back up.
Best of luck...
Nov 05, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
