Question about Insignia Digital-to-Analog Converter for Analog TVs
Have a problem
I have a dtv digital to analog converter i went to hook it up and your owner's manual does not tell you how to hook ti up if you have a switch box which is so i can change from my dvd player to my x box and my ps2 so how do you hook it up and the manual dont tell you how to do that.
  • 67 Answers
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Posted on Jun 11, 2008
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
Since this Curtis RT700 TV is analog, is there an adapter available to make it digital usable?
Yes,the analoge tv must hook through a box that called a Digital Converter box to get a Free AIR DTV broadcasting tvs channels signals.These Digital Converter boxes are no longer on sale by those regular big boxes stores like Walmart or Target.Tries webites like Amazon.com,Ebay.com to a Digital Converter box for any analoge tvs to uses.
Sep 15, 2011 | Curtis RT700 7 in. Portable Television
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
Does my sharp tv model 25k-m180 have a digital tuner
No,all regular tube tvs are analog tv.Must have a converter box hook up to get a free over the air DTV,or must have pay tv services like Cables,Satalite,or Telicoms signals they convert DTV back to analog signal for ur tube tv.
Apr 27, 2010 | Sharp 25K-M180 25" TV
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
No HDTV reception with Jensen JE3269 LCD tv
Looking at the manual, the specifications indicate that this is an NTSC TV. You would need an ATSC tuner (a digital converter box) to convert the digital signals into the analog ones that this TV can receive. You may also need an antenna designed for DTV signals to get a good reception.
Nov 11, 2017 | Televison & Video
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
TV Guardian menu won't come up after hooking up DTV converter box
You may want to check the digital converter boxes and make sure they have analog pass through, it should be listed on the box or the instructions. My Magnavox and Zenith which were bought about a year ago, do not have analog pass through.
Feb 23, 2009 | JVC DRMH20 DVD Recorder
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
332 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
