Question about Mitsubishi WS-65411 65" Rear Projection Television
Full Zoom Mode Problem
My tv seems to always be in Full Zoom Mode. In standard format mode it cuts off the sides, especially the top and bottom. When we are watching tv sports programs, we can not see the score or what period of play they are in. Could someone please let me know how to fix this?
  • nwalton Dec 08, 2008
    I have the same problem. It's not a format issue. Have gone through all formats- it acts like it's only zoomed in slightly, say 110%. This happens even in standard (un-zoomed, undistorted) format setting. Even at 4:3 format (grey bars at left and right), it still crops off the last inch or two of the picture, and shaves off the tops of actors' heads- and the score bars at the top/bottom of screen, as chvalley says. Things are clearly being hacked off that are intended to be visible. Happens irrespective of source- antenna, DVD, component, composite, S-video- doesn't matter.
  • Paul Harrison Jan 02, 2009
    I have the same problem. Over the past 2 months it has been getting worse. The screen is cropped vertically and horizontally maybe 3/4" on all inputs. I have contacted the retialer service tech to have them look into the problem but they have not gotten back to me with a solution yet.
  • 67 Answers
Look on your remote and see if there is a "Format" button, press this to cycle through the different format options, and find one that fits.
If there is not a Format button on your remote, try looking in the setup menus and see if there is an option for formatting or zoom.
Posted on Jun 11, 2008
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I am having trouble getting the screen size back to full size. We used the zoom but that makes the picture to big. My TV is a Auria EQ5588
Hi, The " Size " of a flat panel tv ( when not in zoom mode ) is actually controlled by your programming, if using an hdmi cable from an Hd/Blu-ray player-then whatever format the disc was recorded in is what you'll see ( widescreen/letterbox ) black bars at top & bottom of scrteen ) or full screen. Local over the air digital H.D. brodcast's from networks varie from full screen to letterbox-satellite and cable that are standard definition will almost always letterbox a screen for you. Using T.V.s tuner may alleviate most of the issues. Good luck and I hope this helped. Prodzilla
Apr 10, 2011 | Televison & Video
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have the tv in standard mode, but I am unable to
I bet you are using a cable box or satelite receiver. If so check for aspect buttons on the remote that control these devices. I know comcast says "HD Zooom".
Apr 21, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Jan 07, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Screen is cut off top/bottom
I had the same problem on my 47 inch Westinghoust HDTV. It turned out to be a problem related to my satellite tv (Direct TV) remote controller. Someone inadvertently hit the "format" key and jacked it up. I set back to it's original position and get the full screen. Don't know if you have cable or satellite, but this may help someone having this problem,
Nov 16, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Going nuts!!
If you are using Dish Network, while in SAT mode, hit the star key on the remote (also labled FORMAT). It will start scrolling through certain modes: zoom, partial zoom, normal, stretch... etc)
Jan 26, 2008 | Televison & Video
Mitsubishi WS-65411 65" Rear Projection Television Logo
216 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
