Question about Sharp AL-1641CS Laser Digital Copier
Sharp AL1641CS Flashing H-4 How do I reset it. I am familuar with some sharps using the "crop" to rest codes but not sure on this one !
  • Tim Babcock
    Tim Babcock May 11, 2010
    Crop code disappeared after the digital machines came out.
    I'll look this one up.
  • Sharp Master
  • 2,794 Answers
Its a heat roller error. Its reporting low temperature at power up. It needs a fuser unit or a new thermistor. Usually the whole thing is one assembly.
Posted on Jun 11, 2008
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL 1551CS copier flashing '4' 'H'. Will not clear. This is a stand alone unit, not connected to a computer. How do we clear
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Sharp AL-1551 Laser Printer
My Sharp 1551CS has a "4" and "H" flashing in the quantity indicator. Copier appears frozen.......HELP!!!
To reset the H4 condition on Sharp AL series copiers press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service. Good Luck and Thank You for using Fixya. WheatlandServices
Nov 29, 2010 | Sharp AL-1551CS Printer
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
on Jan 04, 2010 | Office Equipment & Supplies
I have replaced my drum cartridge on my sharp copier, however, the drum indicator light remains on. How do I get the light to go off?
I am not sure about the 208 but try this procedure I have posted here on Fixya. I beleive it may work for you. It sure won't hurt to try.
To reset the drum light on just about any Sharp AL or AR series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Oct 14, 2010 | Sharp AR-208S Black and White Copier
Need driver for sharp al1641cs for ubuntu
Sharp has the print drivers located on their website.
Visit sharp.com and you will have to follow some searches, but in the first search box on the site type in your model number and it will direct you in a few clicks to the driver you need.
Mar 31, 2010 | Sharp AL 1631 Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Sharp AL-1641CS Laser Digital Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
