Question about Kitchen Ranges
Electric oven will not heat up
The oven does not heat up only the lock door light flashes
    Guru:
  • 1,894 Answers
Then the door latch is dead
test with a small pen tip
Posted on Jun 18, 2008
  • 1 more comment
  • dewan nafees ahmed Jun 18, 2008
    the door latch which closes the door is dead. which means the circuit is not getting completed.
    and can u please mention the model number for us
    also if u have a error code please do mention that also
    It sound like the lock switch in the door latch is stuck.
    Check the door locking lever to make sure the the switch is not engaged.
    if not it is in the clock control.
Flashing Locked light. Cannot open the oven door
The oven is locked because the temperature inside the oven has not dropped below the locking temperature. Press Clear/Off button and allow the oven to cool. Oven door should open once it has been cooled below the locking temp.
Feb 17, 2011 | GE Profile JKP18 Electric Single Oven
Self clean is locked but door still open
oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
Dec 18, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 | GE Ovens
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Locked door light flashing
I had the same problem with a gas kenmore oven. I played with the lock mechanism (opened it a little more manually) and it fixed the problem...
Jan 12, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
GE PROFILE electric oven
You are going to have to remove the back panel and manually turn the lock motor to release the door lock catch.   To chat with me live and walk you through how to repair this visit www.applianceoutletservice.com  Thanks, Bill
Oct 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Oven cleaning
There is a lever just under the cook top and above the oven door with a black handle. You need to move the lever all the way to the right. This locks/seals the door and closes the oven vent so your kitchen doesn't get smokey! Once you do this the oven clean light will stop flashing and the oven will heat up.
Mar 28, 2008 | GE Spectra JBP84SHSS Electric Kitchen...
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
