Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Ice maker not working
The ice maker stopped working. The arm is down. I'm clueless - everything else seems fine.
  • saratoga reg Jun 12, 2008
    Hi micbeth1981 -- I thought of your three diagnoses, and the frozen water supply seemed like the cheap problem, so, I emptied the freezer and turned it off, and took a hair drier to the ice maker (focusing on the water line), got it to something above freezing, and what to you know, my ice maker is working again!
    Thanks for the tip -- you are a guru!
  • tylerkelly Dec 05, 2008
    Ice maker not working after door was difficult to close.....got frost on freezeables....then hear something like a big noise in the fridge , like something big falling inside.....now have some stains at he back odf the freeses bottom that look like oil...???? we have emptied the freeses which still works well....any suggestions on the next step.....defrost ....hairdryer on feed tube to the icemaker???, ets ....thanks .....Kevin
    Genius:
  • 1,122 Answers
ONE OF THREE THINGS,THE INLET WATER VALVE ON THE BACK BOTTOM HAS FAILED,THE WATER SUPPLY TUBE IN FREEZER BEHIND ICEMAKER HAS FROZE,OR THE ICEMAKER ITSELF IS BAD,LET ME KNOW WHAT YOU FIND-MIKE
Posted on Jun 11, 2008
  • MIKE major Jun 12, 2008
    PLEASE LEAVE ME A FIXYA
Ice maker does not make ice
there is sometimes an armature that raises when the ice tray is full.you can raise this arm is you want it to stop making ice.look said arm and lower down into on position.it will fold down into a spot near the full level of the ice tray.
Aug 20, 2014 | Refrigerators
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
Ice maker stopped working. Arm seems stuck
Check to see if your vanes are iced in as the heater element in your ice maker may be on the fritz. This means that you may have to replace your ice maker. Take a hair dryer and direct the heat to the ice tray for a while to see if the ice will thaw enough to allow the ice maker vanes to rotate and re lift the stop arm. If this works and it refreezes again and will not ezect the ice cubes then the ice maker will have to be replaced.
Feb 07, 2011 | Whirlpool Refrigerators
Everything seems to work just fine except the ice maker which stopped for no reason. I have checked everything. The water dispenser works well, the water pressure is more than sufficient. We lost power,...
I know of one trick that might solve your problem . First , make sure the lever that swings up and down during cycle is all the way down . Then , pour one eight ounce cup of water into the ice maker where the slots are . Hopefully , when the water freezes , the ice maker's sensor will detect the ice and start the dump cycle . If it does , and everything is OK inside the unit itself , it should be OK after it ejects the ice .
Oct 08, 2010 | Refrigerators
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Sep 05, 2009 | Kenmore Refrigerators
The ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Apr 26, 2009 | GE Refrigerators
ICE MAKER STOPED WORKING
IS THE METAL ARM IN THE DOWN POSITION?
Mar 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Dec 05, 2008 | LG LFX25960ST Stainless Steel French Door...
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
234 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
