Question about Brother HL-2070N Laser Printer
Print Spooler Service
I tried to install my printer because for some reason it was disconnect.
When i go to Add a Printer, it pops up and tells me the print spooler service is not operating..
what do i do?
  • coco1234 Oct 19, 2008
    when i go to stand by is says i cant cause of printer spooler how do i disconnect it
  • 56 Answers
You will need to go to the Control Panel, Click on Administrative Tools and then click on Services. Scroll down to the service "Print Spooler" and right click it. Then click restart (or start if the service is not running).
Posted on Jun 12, 2008
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
Print spooler is not running
go to the website of the printer manufactuer and download the drivers for your printer. upon installation of the new drivers the spooler will restart, to manually start the print spooler service ...........Click start.......then click on the control panel.........then click on administrative tools.........then services..........scroll down the list until you find the spooler and right click it and set to automatic.........Reboot
Nov 27, 2008 | Dell Dimension 3000 PC Desktop
Print problem from network
Try installing the drivers that came on the CD with the printer.
Do the following on the machine connected to the printer:
  • Uninstall all previous drivers from Add/Remove programs (if any exist)
  • Go to Printers in the control panel and from the File menu choose Server Properties
  • Select the current printer driver and hit the Remove button
  • Turn off and unplug the printer
  • Restart your machine
  • Install the drivers that came with the printer from the CD
    Note: Do not unplug the printer till asked by the installer
  • Try to print a test page from the same machine
On the client machines, do the following:
  • Delete the printer
  • Delete the printer driver from the Server Properties window as above
  • Use the Add Printer wizard to add the printer
  • It will automatically install the drivers on the client machine
If the driver could not be removed, try resetting the Printer Spooler service:
To do that
  • Open Control Panel -> Administrative Tasks -> Services
  • Find the Printer Spooler service
  • Right click and Stop
  • Right click and Start
Good luck :)
Oct 27, 2008 | HP LaserJet 1018 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer Spooler service!
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer not getting installed
goto start menu and click on Run
in the box type: services.msc
in the new windows that pops up, scroll down and find "Print Spooler" right click on it, and make sure startup type is set to "automatic", then click on the start button in that same window. Click apply then click ok.. close the services window.. should work now
Apr 06, 2008 | HP DeskJet 5550 InkJet Printer
X3470 printer installation
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
  • go to start menu then run and type "services.msc" then hit enter
  • locate the Print Spooler service in the services list
  • Change turn it on  switch to Automatic mode
Try reinstall
Good Luck
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Printer Spooler Service turns off when I try to print
Un-install the printer and it's associated software via the Control Panel of your Windows PC.
Reboot your computer with the printer turned off and the USB cable unplugged.
Go to the Canoin web site and download the latest version of the driver for your operating system.
Run the driver install following the instructions in the install wizard.
Once the wizard is done, you should be OK again. If not, reboot and test the printer again. If it is still not working properly then you probably have a Windows problem and not a printer problem
Sep 15, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Brother HL-2070N Laser Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
