Projector lamps why are mercury lamps used in projectors which are ridiculously expensive. do they stay cooler than say haolgen or other cheaper light sources, or produce a brighter light for there size.
  • 927 Answers
Good Day,
You are correct when you say it produces a brighter light for their size.
According to the training meetings, all manufactures, they will replace this type of lighting in the future. Samsung already has on their newer units with led/lcd type lamps.
DLP's/LCD Projection TV's need a very bright light to project the image.
Good question.
Posted on Jun 11, 2008
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
My Optoma TX780 projector is not working and all the indicators ie, Temp, Power and Lamp are on. I have changed the lamp though and it worked for a while then the lights came on and would not come on.
you need to reset the Bulb Hours in the on screen menu. it turns off because the bulb contains mercury and after a certain amount of hours the bulb will burst, spreading mercury every where. reset the bulb hours and it should stay on.
Jul 03, 2011 | Optoma TX780 DLP Projector
My Epson EMP-1815 Projector displays replace lamp. Should I replace only the lamp, or the lamp along with the housing module advised by my supplier, which is quite expensive. Does it require an expert in...
If you understand the requirement of specialist lighting and how to handle the lamp, the cheaper option will be fine.
Make certain you rebuild the light box exactly as you took it apart.
Use a camera to take photos.
Jan 04, 2011 | Epson EMP-54 Multimedia Projector
Sharp XG-E650UB LCD Projector
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Aug 07, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Lamp/cover light flashes orange
could be need new lamp
very expensive!!
how old is the tv?
is this the first lamp?
usually get 10000 hours use out of one lamp
Jun 01, 2009 | Televison & Video
CPX-275 real blue display
1st Independant Projector Service Center in Singapore Check out this Company: V3 Systems & Services P/L Block 4010, TECHplace 1, Ang Mo Kio Ave 10, #03-06, Singapore 569626. Tel; 64522679 Hp: 97944886 Contact: Mr Christopher Yew / Mr Jazz Cheong Email: yando@singnet.com.sg / jazzar@singnet.com.sg Finally, We dont have to rely on manufacturer on Projector repair/service. NO more Paying ridiculous price! NO more Paying diagnosis FEEs! NO more waiting for weeks.....to get back projector! And best of all, FREE backup projector. 3 to 5 days, projector back in working condition like new!!!! Charges for repairs $300 -----$500
Nov 14, 2008 | Hitachi PJTX100 Multimedia Projector
Lamp resistance and voltage
1. Projector lamps use customized ballasts that ignite the lamp by charging it with a higher voltage in the ignition phase and then dropping down to a lower running voltage once the circuit is created.
2. Projector lamps CANNOT be tested with an AMP or OHM meter. Projector lamps function by igniting ultra-high pressurized mercury vapor across an ARC tube. At the point where the mercury vapor resides there is no conductive electrical material and therefore testing a projector lamp with an AMP or OHM will not work.
Jul 22, 2008 | InFocus Replacement Lamp Projector Lamp...
Continuity test for a projector lamp?
2. Projector lamps CANNOT be tested with an AMP or OHM meter. Projector lamps function by igniting ultra-high pressurized mercury vapor accross an ARC tube. At the point where the mercury vapor resides there is no conductive electrical material and therefore testing a projector lamp with an AMP or OHM will not work.
Jul 21, 2008 | Samsung - Projection TV replacement lamp...
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
