Question about HP Deskjet 3845 InkJet Printer
I Have a LEXMARK Printer that won't print my mail merged envelopes!!
It's quite urgent, please help me.
I have mail merged envelopes for printing. There are about 2000 envelopes on the word document, and when i press print, it does nothing! I have done this before on my old computer (I have recently changed the computer, printer is the same).
Can you please help me, its URGENT.
    Genius:
  • 2,785 Answers
Try by reloading the drivers for the printer
Posted on Jun 11, 2008
I don't know how to put an envelope in to print it out.
Please follow the steps below on how to print on an envelope:
  • The print side of the envelope is faceup.
  • The paper guides rest against the edges of the envelopes.
  • You print the envelopes with Landscape orientation. Note: If you are mailing within Japan, then the envelope can be printed in Portrait orientation with the stamp in the lower right corner or in Landscape orientation with the stamp in the lower left corner. If you are mailing internationally, then print in Landscape orientation with the stamp in the upper left corner.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so your envelope is correctly positioned.
I hope this information has been helpful. Thanks.
Oct 22, 2011 | Lexmark Interpret S405 Wireless All-in-One...
NEED TO KNOW HOW TO PRINT MORE THAN 1 ENVELOPE AT A TIME. DO LETTERS AND ENVELOPES ONCE A WEEK BUT THE PRINTER WOULD ONLY PROCESS 1 ENVELOPE AT A TIME AND I HAD TO DO THAT ONE MANUALLY.
Hi there !
For printing bulky letters or documents of the same format, I suggest you use the MS word mail merge document. You need to set up the mail merge document and the data of the file. For examples, the list of names, addresses telephone numbers and others should be input to the envelops.
Here's how to create mail merge document file.
1. Open a new blank MS word document or if you have a format already in a MS word format, just use it as default letter.
2. Go to menu bars (Home, Insert, Page Layout, References, Mailing, Review and View) and choose Mailing.
3. From Mailing, click on select recipients, choose use existing lists and find the excel document files that stores all the information like list of customers, company names, addresses, telephone numbers and others.
4. Open it and select table will appear and just click ok to merge it automatically to your default envelope.
5. Now you need to set up or format your envelope. from the Mailing menu, Insert Mail Merge Field will appear and click it to display the headings of your data source. Put the headings wherever you want.
6. After that, press preview result to display the datas. Save your work and it is finished
7
Jan 06, 2011 | Lexmark X 546dtn AllInOne Laser Printer
I am trying to print envelopes (using MS Word mail merge) and printer says "paper mismatch"
first change the page layout setting in the document to envelop size then try to print ..... go to page layout size option the change the paper size to envelop then try to print ......
Dec 14, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer slow to print envelopes through mail merge
This sounds more like a software bottleneck than a printer problem although if printer memory is skimpy and your application is using it for the merge function, additional memory in the printer (it is normally expandable) may help speed things.
The printer cannot make up speed if it isn't getting the data from the computer. If its speed is as rated for simple printing, the printer is likely innocent in the slowdown.
Aug 16, 2009 | Samsung ML-2510 Laser Printer
My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
May 17, 2009 | Lexmark X2600 InkJet Printer
Letter size envelope does not fit into the paper holding tray
Hi cmwww920,
Usually letter envelopes are insert long-way into your printer. I recommend using the Microsoft Word envelope wizard to print Sender and/or Recipient addresses on envelopes. Here's how it works:
1) Launch Microsoft Word.
2) Click Tools > Letters and Mailings > Envelopes and Labels...
3) Type in what you want to see on the envelope.
4) The default feed direction is shown in the lower right corner of the dialog box. To change it, click Options and select the Printing Options tab. Adjust the settings as you please.
5) Click OK to exit the Options Dialog Box
6) Click Print (in the upper right corner of the "Envelopes and Labels" dialog box.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printing mass mailing envelopes
hi
you have not mentioned that what is the printer you are using. any way you should find a sub paper tray near to the main tray, with different types of envelops, marked/engraved on it. some time the same tray is used for this purpose and have the small paper or envelops info on it.
pls mention the printer model if you dont find the tray yet.
Aug 21, 2008 | HP DeskJet 920c InkJet Printer
Mail Merge Print Problem
Was a recipient address created in an Excel spreadsheet or a database? Data needs to be pulled from somehwere to be added to the envelope.
Dec 05, 2007 | Dell Latitude D800 Notebook
HP Deskjet 3845 InkJet Printer Logo
Ben Johnson
