Question about Microsoft Windows Vista Ultimate Edition
Screensaver My screensaver fails to activate. I have made no changes and this is a 9 month old PC Can you help?
  • leslyn Jun 11, 2008
    Thanks, but I have tried all that, changing the timing, etc. The screensaver worked fine for the past 9 months but two days ago failed to activate for no known reason (I had changed nothing). I have rebooted, to no avail.
    Master:
  • 619 Answers
Hi , on desktop right click click screen saver just follow on screen instruction.
Posted on Jun 11, 2008
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
Lenghten time before screensaver comes on
Go to start and type "Screen or Screensaver" it should bring up a choice in the grey menu. Click is and go to Timer and add you time. Or scroll the bar till it says NO screensaver
Aug 29, 2013 | Fujitsu LifeBook A1110 Notebook
How do i set my timer for my screensaver-when my laptop is idle?
The option is under Screen saver options or there is an idle time shut off selection under Power Saver options as well. When you select your screen saver there is are specific options to customize how it shows and how long before it activates. Some screen savers have more options than others.
Oct 29, 2010 | Computers & Internet
No screensaver will activate on my computer
To activate screen saver right clik on the desktop go for properties click on screensaver tabselect screen saver adjust the time to 5 and click on apply and ok button. so that ur screen saver is activated to the selected time.
Jul 07, 2009 | HP Pavilion dv9000t Notebook
I installed 2 gb Of ram to my toshiba satellite a135-s4656 and
Check to make sure the screensaver settings are correct. Adding RAM to a PC won't change how the screensaver works, unless you also added some software that is not letting it sit idle long enough for the screensaver to come on.
Mar 18, 2009 | Toshiba Satellite A135 Notebook
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Report ACER(N~1.SCR has stopped working, how can I repair
it's your screensaver, scr is screensaver (and acer scr is a screensaver from aces) so just change ur screensaver to a windows one and then it will work again :D i don't know why the acer screensavers don't work... if u really want them to work you may want to search their website :D
Sep 23, 2008 | Computers & Internet
Screensaver will not activate...
I would remove the software for your keyboard. This will hand control of the screen saver back over to windows. Some keyboards come with third party software that conflicts with windows. If you want a functional set of "extra stuff" on your keyboard, then your best bet is to try one from another manufacturer.
Jun 16, 2007 | Logitech Cordless Laser Desktop MX 3000...
Microsoft Windows Vista Ultimate Edition Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
