Vizio flat screen has very red tint when using HDTV component cables
I just got an HD reciever today from the cable company. I switched the regular av cables for the HD component cables that the comapny provided with the HD box. When i turn on my Vizio 42" flat screen the picture comes in a strong red tint. What should i do?
Ummm... i have the same problem and its EVERY type of cable that causes the red tint. its the tv itself. replacing all the darker colors with red. explain that?
Posted on Nov 15, 2009
There's a picture type setting in the cable box that must be changed. Call technical support for help on this issue.
Posted on Mar 30, 2011
  • 67 Answers
Sounds like you may have connected the cables incorrectly, or the cable may me bad. The cable company likely provided you with component video cables, which are red green and blue. Ensure that these are connected to the correct plugs on both ends of the cables.
If that does not fix the issue, I would ask for a replacement cable or box.
You may also be interested in buying an HDMI cable if your box supports it.
Posted on Jun 11, 2008
Red tint on the screen an picture
Make sure the signal cable for the input you are using is tight. Possibly try a different cable. Especially if you are using the Red Green Blue component cables. Make sure the issue is across all inputs. If so, try adjusting settings for tint. if that doesn't help you may need to replace the TV.
Apr 09, 2014 | Dynex DX-L32-10A 32" LCD HDTV
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Connected to a sat. we have no sound when we put the T.V. to H.D
What cabling are you using? component? (blue red and green) or HDMI? if you are using component then make sure you also plug the red and white RCA cables in the "audio in" inputs. People commonly think that the component cables do it all but they only carry a video signal. If you are running HDMI through an AV reciever you may need to run an optical cable as well as most AV recievers (unless you buy top of the range) can only switch HDMI video but not sound.
Jul 05, 2009 | Televison & Video
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
When i try to connect my xbox 360 to my Vizio hdtv it doesnt not recognize the connection. I have tried replacing the cord to no avail
I have a Vizio 37' tv with an Xbox 360 and it works fine. I am a Cable repair tech, hook up the xbox using the composit cable first RCA these are the red white and yellow cable to a non high def input on the tv, if that works check the settings in the xbox, there is a screen that will allow or enable HD quality pictures. Also check the Xbox cable itself. at the Y there is a small swiitch that goes from componet to composit you can only get HD if you use the Red Blue Green cables, then make sure you have the TV input set to that input other wise you will have only a blue screen. If that does not work, Hell, call the cable company if you are a customer, they should send someone out to show you how to connect it, and they might not even charge you, we don't, but I work for a smaller company, not ComCast or Cox, If you want to email me you can kml39@yahoo.com, good luck
Jan 10, 2009 | Vizio L37 Television
Switching from HD to Standard screen gets a pinkish/purplish tint in SD only
It is the cable box. Using the HDMI or DVI output on cable boxes is a bad proposition; for some reason the cable box makers have not figured out how to make the HDMI/DVI output work consistently, something that rarely happens with satellite boxes. Use the component output. You will probably not be able to see a difference in picture quality and your problem will disappear. If you liked this solution, please be sure to rate it. Thanks!
Oct 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
1,270 people viewed this question
Top Televison & Video Experts
