Question about Ovens
Viking electric range
The timed AC outlet,the oven light and fluorescent light all failed at the same time.Fuses are all good, bulbs good.What solution to fix is common to them all? Thanks.
    Novelist:
  • 161 Answers
There is another fuse or circuit breaker inside the range. House fuse is at least 50 amps which would be way too large for 110 volt things. Your instructions will tell you where it is. Frigidaire used to hide it under one of the burners. I don't know where it is on a Viking.
Posted on Jun 29, 2008
Part numbers for door gaskets Viking double oven ved0530ss
Go to searspartsdirect.com with your model number. You'll find parts lists and diagrams there
Dec 01, 2017 | Viking Ovens
My bottom oven is not working
Check your fuses, usually located under the top panel of your electric range. You might have to look in the manual for this. If all the fuses are good, then the problem is likely your element. These are easy to replace on most ovens, they just lift and pull out of a socket. Another thing to do is to reset your breaker in the electrical panel. Some times one breaker in the pair will trip and this will kill most hrating elements in an electric oven.
Feb 03, 2015 | Ovens
JA4 jetair electic, light won't work, have replaced with 2 new blubs still does not work ,used glove to handle blubs
fuse isn't any good ussually tied to the ac outlet, check the ac outlet on the range for power it probibly isn't working either,this will confirm it for you.
Jun 21, 2010 | Ovens
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Viking VDSC3656 oven relay (PM010129) failed again
Try to find a relay that has higher contact ratings. Grainger hardware might have one that would fit. It sounds like a design problem and requires a bit of re-engineering to fix it permanently!
Sep 09, 2009 | Viking DEDO205 Stainless Steel Electric...
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Light out
For a fluorescent bulb just get the numbers of it and the length and diameter and go to Lowes or a hardware store and pick it up.
May 08, 2007 | GE SCB1001KSS Stainless Steel Electric...
Ovens Logo
139 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
