Question about Printronix Line Matrix P5210 Printer
Display was lost 38 volt..
If the problem was in the power supply, can I get the schematic so I can repaired the printer bymyself
  • 38 Answers
You will need the factory service manual available for purchase from your Printronix dealer.
Steve W
LazerTek LLC
Posted on Jul 17, 2008
TV not working
have you tried YOU TUBE type in your Question then sit back and watch the videos that appear .
Dec 26, 2015 | Televison & Video
Why my hp designjet 500 smps has high voltage than normal
check power supply and if voltage are good change Electronic module its damaged. this voltage what you are write not normal!
May 21, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Where can I find replacement power cord and adpater?
what country you need to state voltage that come out of power point - is it 120 volt or 240 volt because it has to match with power supply check with seller before buying anything and definately before plugging it into a power point .
. Try amazon see or search in google with Dell AIO V313 ac power supply
Jul 04, 2014 | Dell V313w AllInOne InkJet Printer
Dbx 231 will not turn on. No power
Assuming the cord is well seated and has power, the power supply has likely failed. Take it in for repair or repair yourself. The power supply is VERY simple. Here is a schematic close to your unit:
The power supply is on page 15 and consists of a simple bridge rectifier, filter and two three terminal regulators that generate +/- 15 volts. Any competent electronics person should be able to repair this.
Mar 06, 2011 | DBX 231 Dual Channel 31-Band Graphic Eq
Lightning strike
Good Day;
Make sure when measuring voltages that your'e on the proper ground, all TV's this day has two grounds. The HIT has #'s near the components, LED's that light or do not light. YES, get info to trouble shoot further.
Good Luck, big IRISH.
Aug 26, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Lightning strike
Good Day;
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
COBY TFDVD5605 Portable DVD Player repair tips
all potable dvd player work on 9V through cig lighter in your car adopters comes in three diffrent sizes.
Aug 01, 2007 | Coby TFDVD5000 Portable DVD Player
No Power
Power supply problems are a good possibility. If you have a DC voltmeter, you could check the outputs. In standby mode, you should see at least a +5 volt supply. This standby line is necessary to power the logic circuitry, particularly the microprocessor. In the full on mode (VCR power on), other voltages should be present in addition to the +5. You should see a +12-14 volt, (powers the capstan, video drum, & other motors if present, & possibly a supply for the LCD display of somewhere around -35 volts. A common cause for a non-working power supply in early VCRS ('80s & early '90s), such as Panasonic manufactured rigs, is defective electrolytic capacitors used to filter the above noted supplies, especially the in the +5 & +12 volt lines. Sometimes a capacitor in the primary side of the supply will go bad, causing the dead symptom. Obviously, a schematic is beneficial especially if you are a novice. If by chance bad electrolytics are the cause, and you wish to repair it, I'd suggest using capacitors designed for these switching power supplies, such as the Panasonic FC series available from Digi-Key and other suppliers. If by chance you do have one of these early rigs, these were excellent units. Most early VCRs were made like tanks, very unlike the "made to break" junkers of the last 10+ years.
May 21, 2007 | Panasonic AG-1980 S-VHS VCR
Dvd player is completely dead.
First thing to check is the power cord with it unpluged. Do you get a resistance there or is it open?? If its no reading at all then the power transformer or fuse or current limiter resistor is open. If you do get a reading then you know your power transformer primary is good. Next measure the AC volts comming from the secondary of the transformer. AC volts? Good! Now Find pin 1 or the end pins on the microprocessor. 5 volts present?? No theres your problem get a schematic and troubleshoot the power supply. Yes 5 volts? Measure the display any volts on it?? Ok im sure by now your gonna say no to one of these and like I said get a schematic and conferm all the voltages are present in the power supply. Most common dead problem in dvd/cd players is the power supply ie transformer,regulator, ic, ect, ect. Good Luck
May 10, 2006 | LG DVD 5183 DVD Player
Printronix Line Matrix P5210 Printer Logo
136 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
