Question about Marantz Audio Players & Recorders
Got a marantz 2220B Stereo Receiver. Everything works but getting some unwanted static after the unit has been on for an hour or so. Any ideas? THanks
  • Anonymous Mar 19, 2014
    marantz 2220B has fm no stereo no am at all. good with tape or aux
Did u ever get this sorted out? I have the same problem.
Posted on Feb 26, 2013
  • 1,512 Answers
Hi mdpagan
There are lots of mechanical switch contacts to these old girls. Go about wriggling and tweaking with all the controls and switches on the amp. You may find one of these to be the source of static. These sorts of problems can be sorted out with a squirt of CRC2-26 into the switch or control that is noisy. If it is not this, it may have a leaky capacitor or noisy transistor. the mains switch can produce strange static also when they get a little tired.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
Posted on Jun 13, 2008
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately is a totally different band obviously fm isn't being affected by that whole home broadcast're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
Marantz 2220b does not play in stereo in fm mode. i doxed all pots, & knobs, adjusted pot 304 but no dice. fm light is good, lites up on aux settings
Do you have an antenna attached to the receiver? If you don't, it might not be getting a powerful enough signal to pull in stereo. Also make sure that the mono button is not pressed or faulty.
Aug 26, 2013 | Marantz Vintage Model 2220b Stereophonic...
The stereo light on my marantz 2226b receiver does not come on even on a stereo fm station
my first question is does the light come on when you turn to Tape, Phono, Aux selection? If no lamp is blown, if it does come on then your tuner need to be serviced. FM tuner work is NOT for a novice. I would be glad to take a look at the unit.
Sep 23, 2012 | Marantz Audio Players & Recorders
Will the Marantz SR5004 work with the 901?
By itself, yes, in stereo for stereo analog source material only.
There's good news and bad news for the multichannel hopes you must be harboring.
The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to receive its Active Equalization (unless they, too, are 901's of the same version) and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on most (all?) AV receivers it disables any digital inputs.
The good news. I have a 7.1 setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Just draw the Front L and R analog pre-out from the Marantz to the Bose Active Equalizer then to the new amp. Adjust your speaker levels and enjoy.
Feb 20, 2010 | Bose 901 VI Main / Stereo Speaker
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Marantz 2220B with Sound Problem at Half volume
The most likely cause of this is some DC current working its way through the system. WIthout taking some measurements, it will be difficult to confirm this though. This should not be an expensive repair. Figure on $20 or so for parts (capacitors mostly).
Apr 12, 2009 | Marantz Audio Players & Recorders
Need a user manual
here is a link for youe manual:
please dont forget to rate this solution
Dec 21, 2008 | Marantz SR-9200 Receiver
Marantz SR7500 Home receiver, Digital CD will not play
Verify that the digital output is enabled. This is a switchable output. A brown-out or other power isseu may have shut it down.
Get back to us if that is not the case.
Mar 20, 2008 | Marantz SR-7200 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
278 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
