4.2L Engine
1. Remove serpentine belt
2. loosen power steering pressure and return hoses
3. Remove nut from pressure line mounting on alternator bracket
4. remove power steering pump mounting bolts.
5. Lift pump assembly from engine mounting and remove hoses.
6. Reverse order to install. Fill and bleed system.
NOTE: A new or rebuilt power steering pump will most likely not come with a pulley attached. You will need a power steering pulley remover/installer tool to transfer the pully from the old pump to the new one.
On models equipped with a remote fluid reservoir, disconnect and plug the hose(s) in order to prevent system contamination or excessive fluid loss.
When installing the puller tool onto the power steering pump pulley, be sure that the pilot bolt bottoms in the pump shaft by turning the head of the pilot bolt.
Installing the pilot bolt
Removing the power steering pump pulley
Installing the power steering pump pulley
To install:
When positioning the installer tool onto the power steering pump pulley, be sure that the pilot bolt bottoms in the pump shaft by turning the head of the pilot bolt.
Properly install the drive belt and, if applicable, adjust the tension.
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation
