Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Hampton Bay Ceiling Fan Windward II
I have a Hampton Bay (Windward II 54 in ceiling fan models 523 342 523 127) ceiling fan in my bedroom. I am having trouble with the light. The light has to stay on constantly and will not turn off with the remote. If you do not want the light on constantly than you have to unplug the light bulb from the source. Please let me know how to fix this problem. Thanks. Tammy
  • 4 more comments
  • Anonymous Nov 27, 2008
    I can' remove light bulb
  • jrutick Mar 01, 2009
    I bought a 2nd Hampton Bay remote for my Winward III.
    It runs the fan, but NOT the light. the original remote runs both. how can i get my 2nd remote to also run lights?
  • Anonymous Mar 03, 2009
    i just replaced the ballast, after replacing the lightbulb. I don't get 120vac to the wires connected to the ballast that come through the pipe. I checked the wall switch for the light and it goes hot when switched. Is my receiver not working? For the longest time you could turn the light off and back on if it did not light up - like a bad ballast - but that stopped working. i would replace the receiver but it's 20 feet up in the air. anyway to test the receiver at the fan blade level??
  • chuckntrisha
    chuckntrisha Aug 05, 2012
    hello i just bought new hampton bay i don't know where the black transmitter goes.. does anyone know where it goes in the fan
  • chuckntrisha
    hello i'm new on here i can't figure out where the transmitter for the remote goes on the ceiling fan does anyone know where it goes..
  • chuckntrisha
    i have a hampton bay remote control ceing fan i need help
    Problem Solver:
  • 10 Answers
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
It's a problem with the receiver. Contact Hampton Bay as this is under their lifetime warranty.
Posted on Dec 19, 2008
Could be a ballast problem...we've had to replace in two of our fans
Posted on Sep 28, 2008
    Problem Solver:
  • 7 Answers
The wireing harness in the fan may be wired incorrectly. Does the light come on when u press the fan button? If it does, and is not supposed to u have to get a ladder. Remove the screws around the upper houseing located on the ceiling. sometimes there is a ring that needs just a little turn and will come down and the screws will be visible. Now under that bell houseing against the ceiling there is a bracket that is holding the fan up so removing this cover will not make the fan come tumbling down. In side this bracket should be a black box (remote transmitter). and out of the pipe that goes down to the fan, there should be 3 wires coming up. If there is only 2 wires coming up from the pipe then the fan CANNOT be wired to have one or the other on. Typically. blue white and black. The white is a neutral, dont bother with that one. The blue controls the light, and the black would control the fan or visa versa. The white CANNOT control either. I suggest u shut the lightswitch off controling the fan or find the right circuit breaker to kill the power to the fan before poking around any of the wiring. if u do have the 3 wires u should be able to get your fan working correctly. Nothing to do with the house wiring, dont bother with that side of the transmitter above the fan. Just the wires coming out of the tranmitter box down to the fan. It sounds like its either not an option on that fan, or they just twisted both wires from the fan to the transmitter fan wire. Or all together.
Posted on Jun 11, 2008
    Scholar:
  • 47 Answers
Tammy,
Check the batteries in the remote control, try putting fresh/new batteries in the remote.
Hope this helps!
Instalation diagran for windward II speed control unit
I thought this fan comes with a remote. You can't use both.
Aug 03, 2014 | Hampton Bay 54 in. Windward II Brushed...
Www gpwarranty com
for the Problem with Hampton Bay 54 in. Windward II Brushed Steel Ceiling Fan check the manual
http://lightingworldbay.com/windward-iv-52-indoor-brushed-ceiling-fan-manual/
Apr 25, 2013 | Hampton Bay 54 in. Windward II Brushed...
I have a Hampton Bay Windward II ceiling fan. Fan works fine but fluorescent light doesn't. Have done some troubleshooting. Obviously 120V input is OK otherwise fan wouldn't work. Wires to the...
sounds like there is a lose or broken conection from were the feed to the balast slits from the main fan conection try rewireing from the live imput to the balast see if that solves it.
Jul 30, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Mar 31, 2009 | Hampton Bay 04345 Cruiser Ceiling Fan
Lost screws to attach fan blades on ceiling fan
This is not a 'promo' for Home Depot but you will find the screws there that you need.
You will need 15 screws, with an 'unfinished' appearance, for the attachment of the five blades to the arms, and 10 screws that have a smooth rounded finish to attach the arms to the motor housing. If they do not have it in stock they can order ot for you.
If you have an electrical fan store in your area you should be able to find the items there as well.
If you have an old discarded ceiling fan, take the screws out of it and try them on your current fan, they should work.
Good luck. :)
Mar 15, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Hampton Bay Fan 55295 remote control
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30-Watt Circline bulb and the remote.
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan you will be able to get to the needed additional information.
After downloading and reviewing my fan's Owner's Guide, and reviewing the online FAQs, I called 1-800-330-3267, concisely described the problem, and ordered the parts needed with only the fan name and SKU.
I and am about to order more parts after suffering a power surge (The needed info was in the FAQs). My experience is great customer service and speedy delivery of the needed parts.
One of their FAQ's answers the question:
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Jan 25, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
3,768 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
